@kamala
Good job
Results 91 to 96 of 96
PyIDM version 2020.8.13
@pyIDM pyIDM released this 11 hours ago
Release info:
portable version for windows 32bit and 64bit, no installation needed, just extract to any folder and run PyIDM.exe file
ffmpeg.exe included, you can download latest version here
the binary version ".exe" prepared by "cx_freeze" on python 3.6, windows8x32bit
2020.8.13:
Ability to delete any item while download in progress.
added buttons for open log file, or log folder, issue #134
Fixed arabic language display on linux issue #88
Fixed failed downloads if target folder's name has spaces issue #130
Fix for table colors on tkinter 8.6.9
Stop log auto scroll if user scroll up.
Added horizontal scrollbar for log window.
Fixed fetching youtube channel videos as a playlist, issue #146
Fixed metadata error issue #138
interactive terminal support.
Auto correct file name extension (ask user first) issue #137
Also the help for using cookies was updated..
Using cookies with PyIDM -
Hi Kamala!
I love your program, but something went wrong this time. I don't know if it's my side or yours. Could you look into it? Previous version (2021.4.8) is OK.
I'm getting errors, when trying to start FireDM. It happens after update or after clean unpack of 2021.5.22 version (Win7 x64) . No FireDM.exe in Process Explorer.
After update of previous version:
cx_Freeze: Python error in main script
File "C:\Python\Python38-32\lib\site-packages\cx_Freeze\initscripts\__startup__.py", line 40, in run
File "C:\Python\Python38-32\lib\site-packages\cx_Freeze\initscripts\Console.py", line 33, in run
File "D:\python\myProgects\FireDM\firedm.py", line 11, in <module>
File "C:\Program Files (x86)\FireDM\temp_firedm\extracted\firedm\FireDM.p y", line 31, in <module>
File "C:\Program Files (x86)\FireDM\temp_firedm\extracted\firedm\controll er.py", line 26, in <module>
File "C:\Program Files (x86)\FireDM\temp_firedm\extracted\firedm\setting. py", line 15, in <module>
File "C:\Program Files (x86)\FireDM\temp_firedm\extracted\firedm\download item.py", line 19, in <module>
AttributeError: module 'awesometkinter' has no attribute 'render_bidi_text'
OK
After clean unpack:
File "C:\Program Files (x86)\FireDM\lib\firedm\FireDM.py", line 31, in <module>
from .controller import Controller, set_option
File "C:\Program Files (x86)\FireDM\lib\firedm\controller.py", line 26, in <module>
from . import setting
File "C:\Program Files (x86)\FireDM\lib\firedm\setting.py", line 15, in <module>
from . import downloaditem
File "C:\Program Files (x86)\FireDM\lib\firedm\downloaditem.py", line 18, in <module>
import awesometkinter as atk
File "C:\Program Files (x86)\FireDM\lib\awesometkinter\__init__.py", line 21, in <module>
from .bidi import *
File "C:\Program Files (x86)\FireDM\lib\awesometkinter\bidi.py", line 12, in <module>
import pyfribidi
ModuleNotFoundError: No module named 'pyfribidi'
OK
P.S. Could you add separate update buttons/clicks to youtube-dl and yt_dlp? Of course leave the main update button.Last edited by AllisOne; 23rd May 2021 at 11:13.
yes confirmed.
me also, update to latest version, same error (win7 here).
also download new setup, same error. -
It seems fixed now. Thanks! Check here: https://github.com/firedm/FireDM/releases
Update: I did the update from within the program. It restarted OK. I went to Update tab and there was awesometkinter package to update. I did it, restarted, but now the yt_dlp is stuck on loading (in Update tab). Downloading with youtube-dl seems to work (on youtube at least).
Update 2: Clean unpack is OK.Last edited by AllisOne; 23rd May 2021 at 13:30.
Is Anyone Using pyIDM?
By KermitJ in forum Video Streaming DownloadingReplies: 2Last Post: 20th Feb 2020, 06:13
