Page 2 of 4
FirstFirst 1 2 3 4 LastLast
Results 31 to 60 of 96
    Jul 2017
    North Pole
    this downloads only the video from dplay uk, but not the audio...
    https://www.dplay.co.uk/show/destination-fear/video/brushy-mountain-penitentiary/EHD_288333B
    it says audio is not available, but if i check manually with youtube-dl ...
    edit:
    after checking the video your gui downloaded, it was not complete either, but truncated.
    youtube-dl.exe --list-formats https://www.dplay.co.uk/show/destination-fear/video/brushy-mountain-penitentiary/EHD_288333B
    [DiscoveryNetworksDe] destination-fear/brushy-mountain-penitentiary: Downloading token
    [DiscoveryNetworksDe] destination-fear/brushy-mountain-penitentiary: Downloading JSON metadata
    [DiscoveryNetworksDe] destination-fear/brushy-mountain-penitentiary: Downloading MPD manifest
    [DiscoveryNetworksDe] destination-fear/brushy-mountain-penitentiary: Downloading m3u8 information
    [info] Available formats for 120706:
    format code extension resolution note
    hls-160000mp4a.40.2-eng mp4 audio only [eng]
    hls-64000mp4a.40.2-eng mp4 audio only [eng]
    hls-64 mp4 audio only 64k , mp4a.40.2
    hls-233 mp4 320x180 233k , avc1.42C015, 25.0fps, video only
    hls-462 mp4 480x270 462k , avc1.42C01E, 25.0fps, video only
    hls-855 mp4 640x360 855k , avc1.4D401F, 25.0fps, video only
    hls-1739 mp4 960x540 1739k , avc1.4D401F, 25.0fps, video only
    hls-3317 mp4 1280x720 3317k , avc1.64001F, 25.0fps, video only
    hls-6484 mp4 1920x1080 6484k , avc1.640029, 25.0fps, video only (best)
    actually it fails for some reason with the audio,the log does not say why...
    well,it says invalid argument
    \Downloads\_temp_Brushy_Mountain_Penitentiary.mp4_ parts_\local_audio.m3u8: Invalid argument
    >> file_manager()> post_process_hls() failed, file: \Downloads\Brushy Mountain Penitentiary.mp4
    >> file_manager 2: quitting
    >> brain 2: download error
    >> brain 2: quitting
    edit:
    i downloaded both manually with youtube-dl.exe commandline and muxed them together with ffmpeg, works fine, but not with your gui.
  2. @Kamala
    Thanks for reporting this, I found the problem and I am working on a fix for this issue
  3. Hello everyone:
    this is the latest update regarding false positive,
    "SecureAge APEX", and "Sophos ML" removed their false detection
    now PyIDM.exe has zero false positive with zero detection by 73 engines on virus total, link below,
    https://www.virustotal.com/gui/file/bd064bd86e72599739c8d6b6e738a6d2224bf875a137bdaee4...e631/detection
    thanks
  4. I'm trying to download this video with a german proxy and I get it wrong. What am I doing wrong?
    https://kikageohls-vh.akamaihd.net/i/mp4dyn/b/VOIDb9c48f65-cab1-42e3-819f-38c4015f850c...av.m3u8?null=0
    Jul 2017
    North Pole
    @villaquien: the download link is wrong, get master
  6. How do I get it?
    Jul 2017
    North Pole
    @villaqulen..
    my bad..
    i actually tried it..
    you are doing nothing wrong, just click on the download
    i could download it without any proxies,outside germany..
    you dont have options for quality.. it will download 720p video with 192kbit AAC audio..
    General
    Complete name : \Downloads\index_3584000_av.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 370 MiB
    Duration : 13 min 40 s
    Overall bit rate mode : Constant
    Overall bit rate : 3 779 kb/s
    Writing application : Lavf58.29.100
  8. I don't know what you mean. I tried to download it without a proxy and it didn't detect the video.
    Can you please explain better?
    Jul 2017
    North Pole
    there's nothing to explain.. i added the url you pasted on pyidm ... waited for a while for it to fetch the information...
    clicked on download,and it downloaded it... and i am outside germany..
    maybe you should see the log of pyidm to see the possible error messages..
  10. This is the log with proxy.
    And without proxy.
  11. Originally Posted by villaquien View Post
    And without proxy.
    I think this problem is not related to PyIDM but it is a network problem
    this is what is log said: 'Failed to connect to 37.120.161.249 port 3128: Connection refused'
    the proxy is not good, try to use another working proxy
  12. I finally downloaded the file with youtube-dl-gui but with PyIDM I still have problems downloading. Why?
  13. Hello everyone
    New release "2020.4.8" available for PyIDM which fix some issues and added more features:
    What's new in version 2020.4.8:
    • website authentication option, issue #65.
    • subtitles download, issue #70
    • Added support for famous Audio formats aac, ogg, and mp3 - issue #67
    • Fixed some issues with hls videos i.e. problem downloading audio, and resume error
    • add extra redundant streams while showing format code to identify them, issue #68
    • choose first item in downloads table by default if non is selected
    • Fixed progress reporting 100% before completed merging audio/video or segments.
    • Add referee link option, issue #66
    • Fixed focus for "about window".
    • added http-headers.
    • fixed, thread manager exit without updating the "remaining parts" value
    • unfortunately watch while downloading is no longer available for hls videos.
    link:
    https://github.com/pyIDM/pyIDM/releases/download/2020.4.8/PyIDM_2020.4.8.zip
  14. Originally Posted by villaquien View Post
    @villaquien
    really I am not sure, but i will try again and let you know if i found the problem
  15. me also, i have try 2 days ago, and not work.... simple download and also with german VPN : download don't start....
    @ Aboghazala
    tanxs for your update and your work!
    Jul 2017
    North Pole
    @Aboghazala:
    Awesome.
    Thanks for the update ...
    This is becoming my no.1 app for fetching videos.
  17. @lomero
    @kamala
  18. @Aboghazala: thanks for the new update and for adding popular audio formats and other things.
    I have a few Polish websites I'd like you to look into, if you don't mind. I can download videos from them using a few browser addons, scripts and jDownloader, but I'd like to see your program progress and become the best media downloader in the world .
    A few links (old-school videos), as examples:
    https://vod.tvp.pl/video/rozmowy-przy-wycinaniu-lasu,rozmowy-przy-wycinaniu-lasu,21765408
    https://cyfrowa.tvp.pl/video/zmiennicy,odc-115-ceny-umowne,40862471
    https://ninateka.pl/film/edu-kochajmy-straszydla-podstep-boruty-smf
    To get the stream links I use:
    - The Stream Detector (Firefox extension)(recently left and righ-click action on the icon has changed a bit):
    https://www.videohelp.com/software/The-Stream-Detector
    - Video DownloadHelper (Firefox and Chrome extension):
    https://www.videohelp.com/software/Video-DownloadHelper
    - Skrypt umożliwiający pobieranie materiałów ze znanych serwisów VOD (Script allowing download of materials from known (Polish) VOD services) (Tampermonkey script)
    https://greasyfork.org/en/scripts/6049-skrypt-umo%C5%BCliwiaj%C4%85cy-pobieranie-mater...wis%C3%B3w-vod
    When the script is working you'll see "POBIERZ VIDEO" in the top left corner of the video. After clicking it a new tab will open with video and subtitle links and options to download (POBIERZ), copy (KOPIUJ) and open (OTWÓRZ).
    JDownloader manages to get links (most/all video qualities and sizes) via clipboard from for example The Stream Detector, but pyIDM doesn't seem to do it. It catches the link, but can't find video streams.
    A word of warning about jDownloader - its installer might have adware. I suppose that's why it's not present on videohelp. I managed to install it clean anyway. There's a frequently updated portable version on github made by EIGHTFINITE, but I haven't tried it.
  19. Amazing. Now it's working. Thank you so much Aboghazala
  20. Originally Posted by villaquien View Post
    This is Great!!
  21. @AllisOne
    Sorry for late reply, i was testing the links you provided, and made some modification and get the first 2 links working
    this modification will be available soon with the next release
    [Attachment 52705 - Click to enlarge]
    [Attachment 52706 - Click to enlarge]
  22. @Aboghazala: thanks for making the improvements. And you don't have to feel sorry for late replies or obliged to make them instantly. You just released a new version of the program a day ago. I'm sure you need to sleep and relax sometimes . Make them, if it's fun for you and you learn something new. But I can see you're enjoying working on pyIDM.
  23. Thanks @AllisOne
  24. The new version works very well but the files are downloaded without format. Is that normal? That is, without mp4 extension or AAC extension. And I have to put the extension (.mp4 and .AAC) on them and join the files manually.
    Image Attached Images
  25. Originally Posted by villaquien View Post
    The new version works very well but the files are downloaded without formatting. Is that normal? That is, without mp4 extension or AAC extension. And I have to put the extension (.mp4 and .AAC) on them and join the files manually.
    Oh! This is not good, i think i messed the name extension in this version, as a temporary workaround you can wait until video quality list finish loading and then choose whatever quality you want again (example: mp4-1080-) and it will add the extension to the name
    you can add extension manually to the name field, just make sure video name has the right extension in name field before clicking download button,
  26. Ok thank you.
  27. Member
    Jul 2017
    North Pole
    Aboghazala ...
    was snooping at some stuff and i have the solution too,
    but instead spamming the log and texts on this topic,i will send via pm to you.
  28. Originally Posted by Kamala View Post
    Aboghazala ...
    @Kamala
    go ahead for pm
  29. @ Aboghazala
    your prog is very wonderfully made, but i have little request to add one feature to your next version: add pause to each single download.
    if i have one list of video file, we have stop all and resume all.
    sometime some video are 1 GB or more, if i have list, all video download they stop...
    anyway tanxs for your nice work!
  30. Originally Posted by lomero View Post
    @ Aboghazala
    Hello lomero
    There is already buttons for individual items
    In below screenshot
    the top left buttons for single item resume / stop / delete
    The buttons at top right are for all items, like resume all/stop all/ delete all, and so on
    If this not what you need please let me know
