Results 1 to 10 of 10
  1. I have recently acquired SmartRipper DVD2AVI and TMPEng and have been ripping DVDs with those programs. However, I want to burn a copy of my Neon Genesis Evangelion (Anime) Box Set which is an 8 DVD Series. I know it is going to take a while and a lot of HDD space, but thats not an issue. I need to learn how to encode it with Japanese audio and English Subtitles. I am aware that I will probably have to download more programs and codecs, but I don't mind. If ANYONE could help me out, I would be very appreciative. My e-mail is CobaltInfinity@hotmail.com, I will check back for responses. Thanks for your time and effort.
  2. I read that...unfortunately no where in there does it say HOW to get subtitles (this is all new to me). I also need to know what programs, if any, I need to get to be able to do it. I would also be greatful if someone could tell me how to encode with the japanese audio. Thanks for all your help guys.
    Cobalt
  3. for audio portion, it's really easy, u just need to select the correct audio track in dvd2avi that has the jap audio u want
    as for subs, best way is vobsub/vdub...flaskmpeg/avisyth is also pretty good
    vobsub/vdub:
    http://www.doom9.org/vobsub.htm
    flaskmpeg/avisynth:
    http://www.vcdhelp.com/dvdtovcdflask.htm
  4. Should i leave the smartripper settings the same? In terms of the seperate channel burning that is. It has a multitude of options. Just curious what works best.
    Thanks,
    Ben
  5. CobaltInfinity, main thing is to rip the .ifo file that goes w/ the vob files....u need this for the subs
  6. you can enable stream processing & rip the specific audio & subtitle streams you want if hdd space is an issue, but since you said it's not dont worry about it
    Nov 2001
    Upstate NY
    Hi: I have just started this set for my kids. The way I have been going is in SmartRipper set it to create a VOB file at each Chapter. This gives 20 chapters in the first disk. Every 4 chapters is 1 episode and the last 4 (ie 17 to 20) are the foreign language credits for each episode. Then in DVD2AVI open each set of 4 chapters seperately to divide the episodes. Note the start and stop times for each to help with subtitles. Track 4 is Japanese and Track 1 is english. So save project converting track 4 to wave. Do your encoding either with Tmpeg or CCE. Rip subtitles with SubRip 0.96 and save as Phillips type (*.sub and bitmaps) and divide into 4 files using the times you jotted down in DVD2AVI. Then use SubMux and the SubMux GUI to mux the subtitles to the mpg files for each episode. Software that isn't available here can be gotten at Doom9.net
  8. Corwin, i tried to send you an email with the rest of my questions. Lemme know if you got it.
    Nov 2001
    Upstate NY
    You have mail
