Was trying to get TemporalDegrain2.2.1 working (which that alone seems to be a challenge) and it kept giving me a "system access violation at line 233" error. I examined the AVSI file for TemporalDegrain2 and it seemed that line is when the plugin calls FFT3DFilter. I tried multiple different versions of it, no luck. I even ran FFT3DFilter as a standalone and it still gives me an error so something is wrong with my FFT3DFilter config not temporaldegrain2.
Newer version here https://github.com/pinterf/fft3dfilter/releases
Tried different version of the fftw library?
http://www.fftw.org/install/windows.html
"Filter uses fast external FFTW library version 3 (http://www.fftw.org)
as Windows binary DLL (compiled with gcc under MinGW by Alessio Massaro), which support for threads and have AMD K7 (3dNow!) support in addition to SSE/SSE2.
It may be downloaded from ftp://ftp.fftw.org/pub/fftw/fftw3win32mingw.zip
You MUST put FFTW3.DLL file from this package (not fft3dfilter.dll) to some directory in path (for example, C:\WINNT\SYSTEM32).
Filter will NOT work without it!" -
Ah hah. I solved the issue. There was older version of FFT3W in the plugins+ folder and that was causing conflict I assume. Deleted it an it started working! thanks.
FFT3DFilter Not Found
By lomaidala in forum EditingReplies: 19Last Post: 20th May 2023, 19:45 -
DVD causing Incorrect Disc error, when previously no error
By bishopmaryb in forum Authoring (DVD)Replies: 2Last Post: 16th Jun 2018, 21:24 -
Downloading HDS stream gives forbidden error or auth token error
By vishiwig in forum Capturing and VCRReplies: 1Last Post: 10th Jun 2017, 17:45 -
Error When Trying to Use Fileboom Site - Error Message Appears
By devilcoelhodog in forum Newbie / General discussionsReplies: 5Last Post: 13th Feb 2017, 08:34 -
VirtualDub error: Video Compressor error: The source image format is not
By maddie in forum Capturing and VCRReplies: 1Last Post: 26th Apr 2015, 12:12
