  1. Anonymous
    Guest
    I have a .ts file which I recorded from the HD TV channels in the UK:
    General
    Complete name : Part1.ts
    Format : MPEG-TS
    File size : 378 MiB
    Duration : 15 min 21 s
    Overall bit rate : 3 445 kb/s
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=4, N=12
    Codec ID : 27
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 FPS
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Menu ID : 1 (0x1)
    Format : AAC
    Format profile : LC
    Muxing mode : LATM
    Codec ID : 17
    Bit rate mode : Variable
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 spf)
    Compression mode : Lossy
    Delay relative to video : -1 s 267 ms
    Language : English
    Text
    Menu ID : 1 (0x1)
    Format : DVB Subtitle
    Codec ID : 6
    Duration : 15 min 19 s
    Delay relative to video : 389 ms
    Language : English
    Menu
    Menu ID : 1 (0x1)
    List : 256 (0x100) (AVC) / 257 (0x101) (AAC, English) / 258 (0x102) (DVB Subtitle, English)
    Language : / English / English
    Service name : Service01
    Service provider : FFmpeg
    Service type : digital television
    I was wondering if this video file would be able to be remuxed into an AVCHD DVD without re-encoding since the video stream seems to be H.264. Also, do AVCHD discs support subtitles? What software would I use in Linux Mint Debian Edition 3 to create a disc?
    Thank you in advance.
  2. Extraordinary claims require extraordinary evidence -Carl Sagan
  3. I have a similar question:
    I record HD TV on my Technisat receiver.
    I would like to trim the beginning, end and possible commercials and burn it to AVCHD as that is a format both my Blu-Ray players understand.
    My hope was to do all this without encoding (which I think is what the OP is getting at).
    The thread linked mostly just lists tools that usually re-encode (or don't if the file is compliant).
    Where I personally am confused (and I admit to not having taken the time to sit down and read through everything) is what codecs are AVCHD compliant (both audio and video) and what tools work without re-encoding for all or most of the steps of the workflow.
    I have tried Losslesscut und VirtualDub 2 but they don't work (to be fair, this was several months ago and both have been updated since).
    I am also trying to avoid MultiAVCHD simply because it has not been updated in a long time and I am not sure I can get it to work on Windows 10 with the versions of software it requires.
    Maybe my needs differ from the OP's but I think they are quite similar.
    If I am wrong I will of course make my own thread.
    Be healthy!
  4. I haven't used it myself but understand people have success doing this with VideoReDo
    https://www.videoredo.com/en/index.htm
    Jul 2008
    Old Dominion
    Just FYI, I am running MultiAVCHD on a Windows 10 Pro and Windows 10 Home without any problems.
  6. Good to know!
    I have used it on WindowsXP but have been careful as I didn't want to screw up my other computer...
  7. You can trim your .m2ts file (present in your avchd structure) with XMedia Recode without reencode
    and create an avchd folder with tsMuxer
    Both free and portable
  8. Oh.. that sounds very promising!
    Thanks!
    I might get around to it son.
