Hello everybody...
Apologies for the embarrassing newbie post but I really need to convert a lot of VHS tapes from the 1990s and 80s to digital before they deteriorate any further... Family videos and stuff from college etc...
A few years back I bought a Honestech VIDBOX with the scart to USB converter and cables... If memory serves this came with a CD with software on and the product key on the sleeve but I have since lost the CD and product key.
Is there any way I can still use this? Any software which can make use of it, other than buying it all again?
Thanks for your help!
At the very least you will need drivers for your device. You can get them from:
https://vidbox.company/driver/
But your bigger issue is capture software. If your profile is accurate you are using a Mac and there are few programs against many available for Windoze.
At the very least I suggest you amend your topic header and even contact a mod to move your post, if it is the case, to the dedicated Mac section of the this forum where you will get more assistance. -
Thread moved to the mac forum where you can get more help.
There are few capture programs for OSX. I can't guarantee that echoFX VideoGlide would work for your device because it doesn't work for all USB grabbers, but VideoGlide lists one product from Honestech as compatible. https://www.echofx.com/videoglide.html
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Thanks for the suggestion, but with the software you recommended at $30 I might as well buy a new device, especially with no guarantee it will work. Thank you though!
Honestech VidBox Black Screen
By itsawalk in forum CapturingReplies: 11Last Post: 11th Jan 2020, 22:54 -
VIDBOX or Elgato Video Capture for Mac.
By jmv in forum CapturingReplies: 0Last Post: 13th Sep 2019, 16:18 -
Honestech Video Patrol 4.0...
By Autolite in forum ComputerReplies: 1Last Post: 25th Mar 2019, 21:41 -
Compatible video capture cards?
By Eddles in forum Media Center PC / MediaCentersReplies: 5Last Post: 24th Nov 2017, 16:48 -
Honestech Vidbox Green or piNK blank screen
By nat_urally in forum CapturingReplies: 5Last Post: 28th Nov 2015, 10:13
