i was searching some clips 2 min. and discovered that most clips are hd and their quality is awesome and are small in size,
my question is any software to do so.
i know if you lower bitrate quality drops but how this clips are going
clips info.
data rate 0
tatal bitrate 64kbps
frame rate 29.97
im using windows 10
This is not a sufficient analysis. The bitrate seems to be from the audio stream, not from the video; 64 kbps video in HD resolution can only look "great" if you see almost nothing in it.
Please use MediaInfo for a more verbose analysis. Or even better, share a sample clip with us.
Adjusting characters size in video conversion and other programs
By carlmart in forum Video ConversionReplies: 9Last Post: 4th Mar 2020, 12:19 -
Great Mp4 Quality with Low Size , how ?!
By arioman in forum Video ConversionReplies: 5Last Post: 20th Feb 2020, 06:13 -
Where to buy good quality (low ripple) AC adapters?
By digicube in forum Capturing and VCRReplies: 1Last Post: 10th Aug 2019, 20:10 -
Enhancing low quality video
By heldervrf in forum RestorationReplies: 5Last Post: 21st Dec 2017, 16:12 -
Improve blurry low quality video into clear high quality video.
By Osram123 in forum Video ConversionReplies: 2Last Post: 4th Apr 2016, 01:48
