Obsolete
Filtering requires a reencode. Resizing is filtering. Reencoding degrades the quality unless you're reencoding using a lossless codec. You're not using a lossless codec. Therefore, upscaling, no matter how well you do it, degrades the video quality. It may or may not be noticeable, depending on how well you upscale and reencode.
I don't know if those you 'heard' saying that meant it the way I outlined it or not. I upscale from time to time myself. -
You're usually re-encoding with lossy encoding when you upscale a video = some quality loss by definition
But upscaling is generally worse, because you need an even higher bitrate to achieve a given level of quality as compared to a re-encode of the same dimensions. It's not exactly like this; but a simple way to think of it is a given number of bits is spread over a larger area (larger dimensions) . So the image quality would be worse for a given bitrate when you upscale
If you're filtering, however, or using some exotic methods like neural network processing - then you might be able to increase subjective quality -
I see, thanks for the clarification. I do upscale videos regularly to merge them with higher resolution videos so it's good to know.
Do you lose quality if you encode with the same bitrate or more?.
By Felow in forum Newbie / General discussionsReplies: 21Last Post: 22nd Feb 2020, 21:31 -
Upscaling
By DiggyDre in forum EditingReplies: 2Last Post: 16th Feb 2019, 21:42 -
Does Vegas lose quality when zoomed panned
By Anonymous in forum Newbie / General discussionsReplies: 4Last Post: 29th Feb 2016, 06:49 -
Lose Quality Extracting VOB2MPG? + a Couple Other Questions
By sonicdeth in forum EditingReplies: 20Last Post: 3rd Dec 2015, 04:42 -
Compression, Upscaling, Downscaling, Quality, NuWho Series 1-4
By Danfun64 in forum Newbie / General discussionsReplies: 8Last Post: 6th Apr 2015, 01:03
