Hi, I've got issue with color saturation after conversion.
It only applies (I hope) to 4K 10bits videos
I've noticed that AVS Script creator shows that source is:
LWLibavVideoSource("<file>", format="YUV420P8")
tried changing it to:
LWLibavVideoSource("<file>", format="YUV420P10")
but still on AVS preview and output file colors are dimmed.
Media info shows:
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
I think this is the reason. On files with 4:2:0 (without Type 2) everything is ok (so maybe 8 bits vs. 10 bits is not the issue).
I've tried to convert with p8 - same effect.
I'm after 2 days of reading google, and only solutions are for SD sources (like here https://forum.videohelp.com/threads/353518-Slight-color-shift-with-x264)
and color matrixes, which does nothing for me.
One example. Dark areas are brighten, and red is just washed out
original (picture scale down for size reasons)
[Attachment 52356 - Click to enlarge]
And after conversion (same on AVS preview in MeGUI)
[Attachment 52357 - Click to enlarge]
Regards
P.S. I even tried viewing original file in MPC with limited range to 16-235 instead 0-255 and the image was sill more vibrant than after conversion.
	Is it converting HDR source to rec.709 color space without the tone mapping?
	Essentially - not. My one goal is to reduce file size. No color/contrast/brightness conversion is intended. So I'm pushing down bitrate.
 Original file
 I'm converting with x264, no resize,Code:Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 20 min Bit rate : 52.4 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.264 Stream size : 51.3 GiB (91%) Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primar : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 992 cd/m2 Maximum Frame-Average Light Le : 226 cd/m2
 x264 command line:
 AVS script:Code:--output-depth 10 (tried with and without it) --pass 2 --bitrate 10000 --stats ".stats" --deblock -3:-4 --b-adapt 2 --ref 5 --qpmin 10 --qpmax 51 --merange 20 --me umh --direct auto --subme 6 --partitions all --trellis 2
 As you see AVS Script Creator from MeGui sets wrong colorspace format. Like I said before - changing it to YUV420P10 resulted in no change (same desaturated image)Code:LoadPlugin("C:\Program Files (x86)\MeGUI\tools\lsmash\LSMASHSource.dll") LoadPlugin("C:\Program Files (x86)\MeGUI\tools\avs\plugins\ConvertStacked.dll") LWLibavVideoSource("D:\bb4k.mkv.lwi", format="YUV420P8") #ConvertToYUV420P10() #deinterlace crop(0, 280, 0, -280) #resize #denoise
  Different colors after encoding with MeGUIBy PARALAX in forum Newbie / General discussionsReplies: 28Last Post: 8th May 2019, 02:53
  MeGui Audio Conversion - Speed vs File SizeBy CountChocula in forum AudioReplies: 2Last Post: 3rd Dec 2017, 14:31
  avisyth warmer colorsBy zanzar in forum Newbie / General discussionsReplies: 1Last Post: 19th Nov 2017, 14:56
  I found MEGUI X265 HEVC in MEGUI.ORG !!!!By Stears555 in forum Video ConversionReplies: 11Last Post: 2nd Apr 2016, 15:00
  Avisynth - Overlay on certain colorsBy Ninelpienel in forum EditingReplies: 13Last Post: 13th Apr 2015, 15:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
