Hi,
I am relatively new on this forum, but has found great help so far.
I dont own a blu-ray / DVD player so I rip DVDs and blu-rays and play them via USB-HDD (more convenient anyway).
I used to have an older Samsung LED TV which could play all mkv's with both subtitles and DTS sound, but my "new" from the NU series (UE50NU7475) can neither play DTS sound nor show subtitles. I fixed the sound thing - annoying but now fixed. My problem is now the subtitles.
I dont mind making new mkv's since I still have all my DVDs / blu-rays, but I dont wanna rip more before I find a good and easy solution.
I do it like this: 1) rip using makemkv 2) convert DTS to AC3 using mkv2ac3 (this particular one is PGS)
Now, everything looks and sounds stunning (also 4K works), but no subtitles (I can see and play them in VLC-player but I cannot play them on my TV).
I found an old mkv file which still plays - however I cannot remember how I did that. I analysed using uniconverter which says: video encode: H264 and subtitles1: English-eng text.
So my questions are:
1) How do I see in-which format the subs are put into the mkv which works - so that I can try to do it the same way?
2) How do I put in the subs during the ripping or after so that they work on my Samsung TV? I could try to extract them and have them separately - but I hear people have trouble with that too and since I know it can work with the subs in the mkv - why not go after that?
I greatly appreciate any help I can get. Thank you.
Best regards Søren
Last edited by WannabeZobbe; 15th Mar 2020 at 09:58. Reason: detailed that the sub is PGS
I don't know about the NU serie but for an elderly 8000 these subtitle formats were supported:
[Attachment 52353 - Click to enlarge]
ie for PGS and idx/vobsub you'll have to make an OCR with eg. Subtitle Edit.Last edited by videobruger; 15th Mar 2020 at 14:03.
@videobruger
Yeah, thanks. Its not easy to find the actual models requirements - they are not in the manual.
@ zing269
.srt and ass. are pretty widespread, so thats a good guess and using SE one can convert PGS to srt as videobruger says. However as PGS is a image and srt are text, they dont convert 1:1 - there are many mistakes / typoes in the resulting sub.
HOWEVER - both replys gets me closer to a general solution - other than buying a new TV from a maker who cares about their users. Samsung is just so damn cheap for the quality.
Thank you guys. -
I search for a manual for Samsung NU 8505. On page 152 I found this:they are not in the manual
[Attachment 52360 - Click to enlarge].
Looks like idx/vobsub is supported as internal subtitles in a MKV file.
Even though I have good experience with OCR you can convert PGS to idx/vobsub with BDSup2Sub (or Subtile Edit) and mux it into a MKV file with MKVToolnix.there are many mistakes
How to play MKV files on Samsung Home Theater DVD Player?
By askfriends in forum Newbie / General discussionsReplies: 7Last Post: 25th Apr 2019, 04:13 -
Embedded subs in MKV
By Kristian65 in forum SubtitleReplies: 9Last Post: 11th Dec 2018, 04:43 -
Samsung Bluray player e5300 - MKV files (as data) - CINAVIA
By chochanga in forum DVD & Blu-ray PlayersReplies: 7Last Post: 14th Jan 2018, 14:29 -
MKV not displaying embedded subtitle PLEASE HELP
By maverickluke in forum SubtitleReplies: 1Last Post: 27th Mar 2017, 12:21 -
Subtitles in a black box to cover up existing embedded subtitles.
By Leg_end in forum SubtitleReplies: 4Last Post: 7th Dec 2016, 01:23
