Sometimes,some interlacd still exist when I add some deinterlacing filters which can solve most interlacd.How can I solve them?
What's the solving thinking?Here's my example.
https://files.videohelp.com/u/245858/Young.m2v
Code:MPEG2Source("Young.d2v") Telecide(guide=1) TDeint(mode=2)
QTGMC can solve all interlacd in this case.
But QTGMC always takes away too many details.
So I don't like QTGMC too much but have to depend on it often for the complex hybrid sources.
Damn...
Results 1 to 9 of 9
The sample is hard-telecined.
Why did you use deinterlace filters on telecined film ?
Why didn't your script use field matching for inverse telecine:
No, it can't.Code:AssumeTFF() TFM() TDecimate()
You're not using it correctly. Why would would you use it in the first place for complex hybrid sources?
The sample has illegal video levels and blown-out highlights.
Your question has nothing to do with ripping DVD. Re-encoding and ripping are two different things.- My sister Ann's brother -
You're images aren't showing residual interlacing, they are showing aliasing artifacts from bad deinterlacing. Your source is a mix of telecined film, 30p and 30i, with some orphaned fields. Use QTGMC. There are settings that make it retain more detail -- see the SourceMatch and Lossless options.
I should think that if there are 30p and 30i (interlace and telecine), different parts of the movie would need different styles of cleanup. Likely everything should be 23.976fps for original film, then combined. Pulldown could then be applied to make it all 29.97. Why would you want QTGMC for the telecined parts and the progressive parts?
Agreed, tdeint is a terrible choice.- My sister Ann's brother -
Thanks for correcting my words.I'm a tiro about Re-encoding.
(What's the correct meaning of "dvd ripping"?
How do you find that the sample has sample has illegal video levels and blown-out highlights?
I don't know what is "illegal video levels and blown-out highlights" exactly.
Thanks for your guide. -
I added the SourceMatch and Lossless parameters,and tried different settings several times.
They would influence the result badly.
QTGMC(preset="veryslow",fpsdivisor=2) can solve there problems,
but QTGMC(preset="veryslow",fpsdivisor=2,SourceMatch=X ,Lossless=X,...) can't :
I am willing to solve these problems on clips.
I'm not afraid of complicated steps because it's my learning process.
If I would like to trim,what can I do to solve these problems?
Thanks! -
Yes, lossless and sourcematch do reduce the effectiveness of the antialiasing. With heavy processing like this everything is a matter of compromise. You can try an antialiasing filter afterward but that will blur other parts of the video a bit. Using Overlay() with an edge mask to limit the antialiasing to only high contrast edges might help.
Why are you using fpsdivisor=2? That is loosing half the frames and motion during the 30i portions of the video and making the 24p portions jerky. Though with all the half second cuts it's hard to see.
Deinterlacing
By jseo13579 in forum EditingReplies: 25Last Post: 13th Oct 2019, 16:33 -
Deinterlacing Problem - QTGMC & NTSC Footage
By hickeyguy in forum Newbie / General discussionsReplies: 50Last Post: 8th Mar 2019, 11:41 -
Problem with Deinterlacing/Fieldmatching
By pub0 in forum Video ConversionReplies: 5Last Post: 23rd Aug 2017, 12:47 -
Problem with deinterlacing and edges
By pub in forum Video ConversionReplies: 42Last Post: 14th Aug 2015, 11:21 -
Bob deinterlacing
By Hypersonic1 in forum Video Streaming DownloadingReplies: 5Last Post: 28th Mar 2015, 17:46
