Hello all...
I was wondering if anybody could recommend any free software for MacOS (or Windows) which has the ability to splice an MPEG or raw VOB file extracted from a DVD or captured by other means and export the clip without re-encoding (and therefore losing some quality and changing the size or bitrate)?
I currently recommend MPEG Streamclip from http://www.squared5.com for doing this with MP4 files but unfortunately the free version doesn't support earlier MPEG types...
Can anybody help? I really would rather not have to convert to MP4 before doing this as I can never configure HandBrake or anything similar to output an MP4 at exactly the same quality and specifications as the MPG or VOB original.... (unless anybody can explain how to do that?).
Thank you for your help!
	I don't know about free but SmartCutter does almost all formats including MPEG-2 and VOB and the newer formats with no conversion, It just regroups the GOP, It's worth $50 if you use it a lot.
  Cutting/trimming mp4 files without re-encodingBy CaptainCatholic587 in forum EditingReplies: 10Last Post: 13th Jul 2020, 01:23
  IFO hack: fool DVD player into playing MP2/MPG files, not just VOB?By TechLord in forum Authoring (DVD)Replies: 4Last Post: 28th Jan 2018, 21:01
  Can Sound Forge not open MPG / VOB files?By guy24s in forum EditingReplies: 14Last Post: 17th Dec 2017, 04:50
  Batch frame trimming and conversion MPG to animated GIFBy loopo in forum Video ConversionReplies: 7Last Post: 23rd May 2016, 08:01
  Splitting, Trimming, and Joining mts files ?By NewTwoVideo in forum EditingReplies: 2Last Post: 11th Feb 2016, 13:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
