    Aug 2006
    Australia
    Hi
    Got a bunch of DVD's ripped onto my hard drive. As they are music videos I would like a quick and easy way to split them into chapters, preferably without reencoding them.
    Any ideas on how to do that on a mac?
  2. Drag the first . vob file onoto MKVToolnix. The other .vob's are automatically included.
    Select "Before chapters" as split mode.
    [Attachment 52348 - Click to enlarge]
  3. I'm a Super Moderator johns0's Avatar
    canada
    Thread moved to the mac forum where you can get more help.
    Aug 2006
    Australia
    For some reason that does not work.
    I drag and drop the first VOB and then select BEFORE CHAPTERS then type "all" foir Chapter Numbers.
    It fails with:
    No chapters in source files or chapter files found to split by.
    Although if I use makemkv first then it works fine?
