Okay, so I have a friend who likes to capture HDTV. And sometimes he records stuff for yours truly.
Unfortunately, he only has a laptop at his disposal. And the audio signal coming through the HDMI cable is unfortunately only 2.0.
I really want him to be able to record true 5.1 sound. Now, after a bit of searching I did stumble upon this product here: https://www.amazon.ca/dp/B005M19I0K
But as it is most every time, the specification info is a tad vague. What I'd like to know is, will it be able to capture 5.1 sound through the Optical in connection? And if so, will it just need the Optical in and then the USB in the laptop or will he need to connect more paraphernalia together?
Thank you for you guys' help in advance.
-Arian
Results 1 to 1 of 1
potplayer sound lag on external monitor
By jokealot in forum Software PlayingReplies: 1Last Post: 7th Oct 2019, 23:01 -
Adding a new External Capture Card to my Hauppauge Colossus Internal Card
By MounaLafi in forum Capturing and VCRReplies: 30Last Post: 21st Feb 2019, 14:40 -
Combining external Hard Drives in Wins 10 via Spanned or Stripped question.
By siratfus in forum ComputerReplies: 8Last Post: 21st Dec 2018, 21:36 -
Panasonic HC V720- no sound when external mic is plugged in
By g_knoll in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Apr 2017, 07:25 -
Do I need external USB sound card ?
By ausrob in forum Media Center PC / MediaCentersReplies: 14Last Post: 25th Mar 2017, 19:10
