Hi, I'm new to editing.
I'm looking to render small files (<8Mb) to post on Discord (apparently only mp4s work) and I wanted to know if the render settings and format I'm using is the most appropriate for this type of small videos.
Below is a template for videos that have less than 15 seconds. For longer videos I bring down the average bit rate
[Attachment 52296 - Click to enlarge]
I have some quick questions about some options here
What does Number of reference frames mean? And what is the best choice for small videos? What happens if I increase it?
The same goes with Number of slices and Two-Pass.
Does changing the frame rate and maintaining the bit rate have any effect on the video quality?
thanks!
Just use one of the defaults. They are designed to provide good results without having to learn about all the options.
Two rules of thumb:
Using anything other than the original source frame rate makes it worse. (With certain exceptions)
Higher bitrate within the same codec provides better quality, with a LOT of provisos.
You may want to take a short segment with moderate motion, 10 or 15 seconds and experiment with different settings to see what the effects are for yourself. -
I think "use one of the defaults" is a horrible answer to his question, not gonna lie. Had to make an account just to say this. He's asking what type of codec and potential settings/preset he should use to guarantee a small file size. "one of the defaults" include ones that'll make a 30 second video 2mb or 100+ MB, which can be confusing if you aren't too familiar with how render settings work. Not all versions of the program have the "estimated file size" in the corner of the render screen the newer ones have.
For discord I've been using the "Memory stick" presets in the Sony AVC/MVC for 50-90 second videos. You don't really need more than SD for goofy discord videos either way, you're better off just rendering stuff normally and posting to streamable or unlisted youtube if you want high resolution/bitrate results. -
Also a reminder, there is voukoder plugin for Vegas. Installation has two stages: Voukoder application and then plugin. Better results could be obtained specifically for starving bitrate because of using x264 encoder. This is a late response, but anyway, op might need 2pass for his specific reasons perhaps but voukoder can encode with CRF method which is one pass only. Huge advantage.
Sony Vegas Render Has weird bars
By xpsstudios in forum EditingReplies: 8Last Post: 20th Jan 2017, 21:16 -
How to use sony vegas to process videos
By achy635 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2016, 16:55 -
Sony Vegas glitching videos while editing
By Clever Sleazoid in forum EditingReplies: 19Last Post: 9th Sep 2015, 15:23 -
What settings to use to render videos which are the combination of clips fr
By avz10 in forum Video ConversionReplies: 9Last Post: 11th Aug 2015, 22:07 -
Unable to import mp4 videos in sony vegas pro 13.Only audio out of video.
By WingSaber in forum Capturing and VCRReplies: 1Last Post: 12th Jul 2015, 16:56
