hello everyone i have got a question i need to ask right i have recorded a movie off the tv onto a usb stick. but when i plugged it into the computer it is a raw disc/ RAW format not NTFS format so my computer shows it has been empty. but it has a movie on it so is there anyway to open the usb stick with maybe a software or something cos i have tried cmd / command prompt. and that says the usb stick is a raw disc/RAW format and cmd/command prompt. wount read raw disc/ RAW format and it wount open it. so can anyone tell me of a way to open a raw disc. / it is a RAW format so how do i open this on my usb stick can anyone please help me with this problem.
The following worked for me with linux hdds ( often not recognised on Windows Os): Download diskpart (it's a command line utility) / Run a comand line and type diskpart
Activate the partition of your usb thumb drive, type on your keyboard:
diskpart > list disk (it will list all your hdds) > select disk (+number of disc) > list partition (all partitions will be listed) > select partition (+number of partition)
then type: activate (keep the window open after that !)
Now it's been activated but Windows may not have assigned it a letter still (D,E,F etc..) so try to assign a letter with Ext2 Volume manager (free and useful for linux hdds)
If it works the drive can be opened directly, otherwise: Use Photorec to recover your videos (very efficient tool and free)
Good luck*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
raw
By JAX75 in forum Video ConversionReplies: 12Last Post: 26th Aug 2018, 12:44 -
No format plays as smoothly as raw MiniDV AVI files
By jackdarabbit in forum Newbie / General discussionsReplies: 15Last Post: 19th Feb 2018, 18:04 -
Photoshop CC 2017 cannot open camera raw and liquify not working
By kwanami in forum Software PlayingReplies: 1Last Post: 19th Jul 2017, 21:06 -
Blu-Ray ISO, nothing will open it on my computer, burned disc either
By Guphanti in forum Authoring (Blu-ray)Replies: 34Last Post: 13th Jan 2016, 13:58 -
SATA HDD in IDE computer! Video files missing? Sata HDD now RAW!
By visionman in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2015, 12:35
