can any one help
i have lord of the rings on svcd from a mate he can copy it using
blind write
i have tried blindwrite
clone cd
nero
but i can not get it to read the whole disc
not sure if it is overburnt and dummy files
can any one help
Doug
maybe try just using Nero's image writer to burn an image of the disc, then mount with daemon tools, and do a str8 disc copy with Nero, or whatever burning software you prefer.
I have a similar problem. I tried to copy one of my SVCD with Easy creator 5. I have only one CD-RW so I created an image on HDD then I burn a blank CD from this image. Well the copy just created doesn't work.
What if I try to copy direct without creating CD image? Do you think it will work??
Thanks, -
Originally Posted by Gerula
thanks fantomlord,
i'll try tonight. hope it will work.
If it will, I'll give you a beer :o))
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
cannot copy 22.5 Gbyte file with Win XP copy command
By maxtrack in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 14:12 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
