I'm a musician, with no video editing knowledge, and I'm trying to make very simple videos of images with moving particle effects and volumetric lighting, like in this video.
https://www.youtube.com/watch?v=n0AY4ebPy4w
I found a free pack of dust of lighting effects from Rocketstock, but I can't figure out how to use them properly with the techniques I've tried to learn. All of the effects are over a black background. I'm currently using NCH Software's "Videopad". When using their chroma key option "green screen" on the black background of the overlay, I get dramatic pixilation and tearing in the lighting. When I try to instead blend the overlay with the image by transparency, the gray from the overlay darkens the original image, and the lighting from the overlay is too dim to notice. There's also a free app on my computer called "Video Editor", and it has some premade effects, but you can't modify the colors, speeds, or density, to my knowledge. It also seems that I can't add the Rocketstock effects package to the program.
I'm trying to avoid subscribing to Adobe After Effects, which is why I'm experimenting with Videopad. I don't mind buying a video editor that would allow me to accomplish these effects, but of course I don't want to buy one that can't accomplish this at all. I'm looking for help with technique, software recommendations, and any other advice or info you have.
You don't "chroma key" the background. You use an overlay with blend mode set to "screen". I don't know if videopad has layer blend modes
Or you can use another free editor like shotcut , which has layer blend modes
https://www.videohelp.com/software/Shotcut
The "math" is just like photoshop blend modes
https://photoblogstop.com/photoshop/photoshop-blend-modes-explained
Video lighting help
By Danitwelve91 in forum EditingReplies: 4Last Post: 9th Jul 2019, 02:31 -
sound effects and video effects used in japan tv shows
By rocco123 in forum EditingReplies: 0Last Post: 30th Oct 2018, 11:16 -
Need lighting equipment suggestions for recording VR videos
By Level 2 VR in forum Video Streaming DownloadingReplies: 6Last Post: 27th Jan 2017, 04:46 -
Best Special Effects Software for 3D Particle Effect
By TheJDKProductions in forum EditingReplies: 13Last Post: 3rd Nov 2015, 05:04 -
Canon HF G10 - About Lighting
By abyssin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 18th Jul 2015, 06:12
