hi
is there capture software out there that can capture via an advc 100 straight to mp4 in one step like premiere 6 could if avi?
DV to mp4? Double butchering.
I don't think I've ever seen DV in an MP4 file. You can mux it into a MOV file though -- that might be close enough for you. I don't know if any capture programs support it directly. Attached is a short sample.
Maybe virtualdub?
https://encodingtalk.com/threads/virtualdub-save-direct-to-mp4-fraps-to-youtube-with-e...encoders.2446/
Don't have my firewire card yet to test my advc 100... -
Back in the day I could transcode from an ADVC to mpeg2.
I know that is not what you are asking but I doubt it. You might find some software to mux from DV to mp4 but, again, I doubt it. Muxing into containers is only of value if your player can support it. VLC might. But try and play that theoretical mp4 to a tv either by BD-player or usb and all falls flat.
And you are more likely to want to edit the recording. So keep it as DV.avi, edit it, and then transcode to a compatable codec for mp4. -
And maybe not.
You really should research your suggestions before you commit them to print. That capture program is available for direct download on this site and is Nagware. You get 20 minutes maximum in trial mode. Maybe enough to test it. But.....
Then read the programs remarks. 'Depends on input source' or words to that effect.
Better to test these yourself when you have the kit than make wild suggestions.
FFMPEG Conversion from MKV to MP4 returns a empty MP4 file?
By lolmaisine in forum Video ConversionReplies: 4Last Post: 6th Mar 2019, 07:45 -
Split mp4 file into specified size (part1.mp4, part2.mp4 etc.)
By TubeBar in forum EditingReplies: 7Last Post: 1st Feb 2019, 22:41 -
how can i join two videos a1.mp4 + a2.mp4 = a12.mp4
By sommers in forum Newbie / General discussionsReplies: 14Last Post: 8th Jun 2017, 18:01 -
Homemade mp4 files quality vs. ripped movies in mp4 format
By MrMX in forum Newbie / General discussionsReplies: 11Last Post: 26th Nov 2015, 22:12 -
How to open .MP4 files in virtualdub? (i want to sharpen mp4
By fuc847 in forum Video ConversionReplies: 27Last Post: 22nd Apr 2015, 08:06
