Try DVD-Fab Video Downloader and rip Netflix video! Or Try DVD-Fab and copy Blu-rays! or rip iTunes movies!
  1. Member TeNSoR's Avatar
    Mar 2014
    Hungary, Debrecen
    Hello!
    I'd like to rip this DVD, Will you help me, guys? Thanks in advance!
  2. If you have unencrypted MPEG video you've already "ripped" the disc. Are you asking how to compress it? It's progressive video, it doesn't need any deinterlacing or other special handling. Use any encoder/codec you want.
  3. Member TeNSoR's Avatar
    Mar 2014
    Hungary, Debrecen
    Yes, I'd like to compress it but i don't know how to remove the green lines on the both sides.
  4. The easiest way to get rid of those green lines is to crop away that edge of the frame. Handbrake lets you manually specify cropping. To get rid of the them while keeping the picture is much harder. It will require some advanced filtering.
  5. Here's a cheap trick using AviSynth. The chroma of the green lines is replaced with the chroma above them:
    Mpeg2Source("C:\Users\John\Downloads\Demuxed sample.d2v", CPU2="ooooxx", InfMpeg2Source("C:\Users\John\Downloads\Demuxed sample.d2v", CPU2="ooooxx", Info=3)
    src = last
    v2 = Crop(0,0,-0,-2).AddBorders(0,2,0,0) # a second copy of the video shifted down by two lines
    umask = UtoY().mt_binarize(20, upper=true).PointResize(width, height) # a mask based on the U channel
    MergeChroma(src, Overlay(src, v2, mask=umask)) # overlay the chroma of the shifted video wherever the green lines are
  6. Member TeNSoR's Avatar
    Mar 2014
    Hungary, Debrecen
    Thank you! I use x264 encoder, if possible would you kindly suggest some advanced filters?
  7. Member TeNSoR's Avatar
    Mar 2014
    Hungary, Debrecen
    src = last
    Much appreciated!
