  1. I have a VCD Film in 3 CD'S. I would like to copy this but each CD is more than 700mb!!!! I wonder if there is a way to split it again
    Mar 2002
    cleveland/cincinnati
    dude just copy the cd with your burning software! It will burn it! did you even try copying the cd? Try it then tell me what happens...
  3. 1 VCD = ABOUT 759MB
    MY CDS= ABOUT 700MB
    NEED TO ADD MORE PARTITIONS
    Jul 2001
    Indonesia
    Just copy them !!!
    As long as the running time is not more than 80 mins,it'll burn !! (in a 700 MB cd-R)
    I guess vcd's uses a different algorithm so it kinds of displays a biggers size than the cd's capacity
  5. http://www.ping.be/satcp/realsize01.htm
    after overhead and without overburning you should be able to fit 804MB on an 80min 700MB CD-R.
  6. burning at mode 2x/a allows u to fit about 800 MB on 700 MB cd-r and 750 MB on 650 MB cd-r...basically, the tracks on the cd are burned closer together...(my best guess cuz of following)
    that's how they were able to progress from 74 min->80 min->90 min cd-rs..even though the burning surface was still the same size, cuz the laser burns the groovers ever closer together
