Anyone know of program that can put a white border around a photograph jpg or png with a click without going through the roundabout photoshop way?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
If it's something you're going to do often, you can make a ffmpeg batch file and put it in your sendto folder.
"c:\users\[username]\AppData\Roaming\Microsoft\Windows\SendTo"
So you can use the windows context menu. ie. right click an image => send to => [select the batch name, make sure you use a descriptive one], it will automatically process it. If you group select a bunch of images (shift or ctrl), it will process the entire selection
you would use -vf pad in ffmpeg
https://ffmpeg.org/ffmpeg-filters.html#pad-1
e.g add 8 pixel white border, output images to directory "V:" as png, with the same name as input files
Code:for %%i in (%*) do ffmpeg -i %%i -vf pad="width=iw+16:height=ih+16:x=8:y=8:color=0xFFFFFF" "V:\%%~ni.png" pause
Hi David
Just as an alternative, and quite easy... something I do alot, I use Irfanview's canvas and/or overlay feature to decorate my screenshots.
I get a bit carried away with my screenshots so sometimes I load the image in Irfanview, go to Menu-Image-Change canvas size, and select the number of pixels I want to surround the image. Selecting top, bottom, left, right sides, whatever # of pixels (can be different for each side). The canvas color is selected using the standard-fare Windows color wheel (color picker) - I Save-as whatever the default image is - .jpg, .png. I use Save-as to preserve the original image until I like the result.
The overlay/watermark feature is nice too, you can get a bit more professional at an easy price ... create a simple background whatever size larger than your overlay image (original), using create new empty image. Once you have a simple background in the color you like drop the original on top using Edit-Insert overlay. You have a few choices in location - centering the pic makes the most sense. You can add a bit of transparency to your overlay, it actually works in some cases - looks kinda cool. I Save-as to preserve the original image.
You can also use any image you might have as a background, or find one, cut to size, and then drop your original onto it as well (Insert overlay) - this usually looks the best. The color picker works for simple colors but putting a nice pic onto the top of a nice wallpaper (whatever) really can doctor up a pic.
Again, just some options... and it took longer to type this than it would to do it in most cases and the result is very decent. -
While I agree there should be plenty of offerings to do this, especially in batch (free too), with ffmpeg, gimp, irfanview, etc., what is so "roundabout" in Photoshop? You can easily create a set of actions that you incorporate into either the "image processor" or the "batch" options, and with the batch one, you can just drop files onto them and they run. This sounds just like what the others were suggesting.
removing border from logo with transparent
By vanhoa in forum EditingReplies: 0Last Post: 12th Oct 2019, 09:26 -
Black border when recording with LGP Lite
By ynobry in forum CapturingReplies: 2Last Post: 4th Jul 2019, 02:27 -
Adding black border to increase resolution for stabilization?
By killerteengohan in forum RestorationReplies: 13Last Post: 6th Jan 2019, 19:56 -
Issue with Aegisub subtitle border
By Nantes in forum SubtitleReplies: 1Last Post: 22nd Nov 2017, 03:18 -
Add border to the bottom of an mkv
By naszdom in forum Video ConversionReplies: 3Last Post: 28th Mar 2015, 12:04
