Can you use ED Beta Metal tape (same as betamax tape) in a regular Beta VCR without damaging the heads? Of course , I know the quality will not be better and maybe inferior to regular beta tape. I ask because my ed beta machine no longer rewinds....and I was thinking to rewind the tapes in my superbeta machine .
Definitely can’t record or play an ED-Beta tape in a non-ED Beta machine as the metal formulation requires much higher record/playback strength. Sony stated in the ED Beta manual not to use ED Beta tapes in a regular machine. You can’t even erase them with a bulk eraser, I tried it a lark once. Didn’t even affect the control track with the eraser directly on the bare tape!
As I recall, during FF and RWD, the tape is kept away from the videoheads by a cushion of air, so that’s not an issue. A real concern is that the tape is still in contact with the upper and lower drums an since the tape is more abrasive will cause additional wear. Given the repair parts are hard to find, I’d treat your machines with care.
If the rewind on your ED-Beta isn’t working, best to get it repaired while parts are still available. It may only be the rewind that doesn’t work right now. But if I recall correctly, during unloading, the left spindle (the rewind spindle) moves slightly in reverse as part of the process. Eventually, as it doesn’t work correctly, your tape won’t retract correctly and likely jam.
Beta rewinders are rare. mrbetamax.com has a couple of Sony rewinders, but they’re not cheap, $125 & $195. But still better than adding undue wear and tear on your machines which are getting rarer and harder to fix. A couple of alternate possibilities are to find a cheap Beta machine and use it just for FF and RWD or possibly remove the right spindle on VHS rewinder and use that. Be careful it’s likely it may snap the tape if it reaches the end.
Beta with s-video out
By kodec in forum RestorationReplies: 21Last Post: 8th May 2024, 16:23 -
SubRip - Version: 1.57.0 Beta Do Not Work Properly
By devilcoelhodog in forum SubtitleReplies: 1Last Post: 10th Sep 2018, 21:19 -
Problem with Sony Hi8 Metal-E tape
By VSz in forum Capturing and VCRReplies: 6Last Post: 10th Jun 2017, 15:38 -
MakeMKV Beta
By Arthur_Ballsack in forum Authoring (Blu-ray)Replies: 1Last Post: 21st Jun 2015, 15:25 -
MPC-BE v1.4.5 (build 364) x64 beta no work
By cam in forum Software PlayingReplies: 2Last Post: 7th May 2015, 17:54
