It seems that adding this command improves compression a bit:
-profile rext -rc-lookahead 32 -refs:v 16 -bf 3
What else can be tuned with lossless preset?
for all options create a new textfile named hevc_info.cmd with the following 2 lines:
ffmpeg.exe -h encoder=hevc_nvenc
pause
execute it -
Which options?
ffmpeg.exe -h encoder=hevc_nvenc doesn't show info about lossless:
Code:Encoder hevc_nvenc [NVIDIA NVENC hevc encoder]: General capabilities: delay hardware Threading capabilities: none Supported pixel formats: yuv420p nv12 p010le yuv444p p016le yuv444p16le bgr0 rgb0 cuda d3d11 hevc_nvenc AVOptions: -preset <int> E..V...... Set the encoding preset (from 0 to 11) (default medium) default 0 E..V...... slow 1 E..V...... hq 2 passes medium 2 E..V...... hq 1 pass fast 3 E..V...... hp 1 pass hp 4 E..V...... hq 5 E..V...... bd 6 E..V...... ll 7 E..V...... low latency llhq 8 E..V...... low latency hq llhp 9 E..V...... low latency hp lossless 10 E..V...... lossless losslesshp 11 E..V...... lossless hp -profile <int> E..V...... Set the encoding profile (from 0 to 4) (default main) main 0 E..V...... main10 1 E..V...... rext 2 E..V...... -level <int> E..V...... Set the encoding level restriction (from 0 to 186) (default auto) auto 0 E..V...... 1 30 E..V...... 1.0 30 E..V...... 2 60 E..V...... 2.0 60 E..V...... 2.1 63 E..V...... 3 90 E..V...... 3.0 90 E..V...... 3.1 93 E..V...... 4 120 E..V...... 4.0 120 E..V...... 4.1 123 E..V...... 5 150 E..V...... 5.0 150 E..V...... 5.1 153 E..V...... 5.2 156 E..V...... 6 180 E..V...... 6.0 180 E..V...... 6.1 183 E..V...... 6.2 186 E..V...... -tier <int> E..V...... Set the encoding tier (from 0 to 1) (default main) main 0 E..V...... high 1 E..V...... -rc <int> E..V...... Override the preset rate-control (from -1 to INT_MAX) (default -1) constqp 0 E..V...... Constant QP mode vbr 1 E..V...... Variable bitrate mode cbr 2 E..V...... Constant bitrate mode vbr_minqp 8388612 E..V...... Variable bitrate mode with MinQP (deprecated) ll_2pass_quality 8388616 E..V...... Multi-pass optimized for image quality (deprecated) ll_2pass_size 8388624 E..V...... Multi-pass optimized for constant frame size (deprecated) vbr_2pass 8388640 E..V...... Multi-pass variable bitrate mode (deprecated) cbr_ld_hq 8 E..V...... Constant bitrate low delay high quality mode cbr_hq 16 E..V...... Constant bitrate high quality mode vbr_hq 32 E..V...... Variable bitrate high quality mode -rc-lookahead <int> E..V...... Number of frames to look ahead for rate-control (from 0 to INT_MAX) (default 0) -surfaces <int> E..V...... Number of concurrent surfaces (from 0 to 64) (default 0) -cbr <boolean> E..V...... Use cbr encoding mode (default false) -2pass <boolean> E..V...... Use 2pass encoding mode (default auto) -gpu <int> E..V...... Selects which NVENC capable GPU to use. First GPU is 0, second is 1, and so on. (from -2 to INT_MAX) (default any) any -1 E..V...... Pick the first device available list -2 E..V...... List the available devices -delay <int> E..V...... Delay frame output by the given amount of frames (from 0 to INT_MAX) (default INT_MAX) -no-scenecut <boolean> E..V...... When lookahead is enabled, set this to 1 to disable adaptive I-frame insertion at scene cuts (default false) -forced-idr <boolean> E..V...... If forcing keyframes, force them as IDR frames. (default false) -spatial_aq <boolean> E..V...... set to 1 to enable Spatial AQ (default false) -temporal_aq <boolean> E..V...... set to 1 to enable Temporal AQ (default false) -zerolatency <boolean> E..V...... Set 1 to indicate zero latency operation (no reordering delay) (default false) -nonref_p <boolean> E..V...... Set this to 1 to enable automatic insertion of non-reference P-frames (default false) -strict_gop <boolean> E..V...... Set 1 to minimize GOP-to-GOP rate fluctuations (default false) -aq-strength <int> E..V...... When Spatial AQ is enabled, this field is used to specify AQ strength. AQ strength scale is from 1 (low) - 15 (aggressive) (from 1 to 15) (default 8) -cq <float> E..V...... Set target quality level (0 to 51, 0 means automatic) for constant quality mode in VBR rate control (from 0 to 51) (default 0) -aud <boolean> E..V...... Use access unit delimiters (default false) -bluray-compat <boolean> E..V...... Bluray compatibility workarounds (default false) -init_qpP <int> E..V...... Initial QP value for P frame (from -1 to 51) (default -1) -init_qpB <int> E..V...... Initial QP value for B frame (from -1 to 51) (default -1) -init_qpI <int> E..V...... Initial QP value for I frame (from -1 to 51) (default -1) -qp <int> E..V...... Constant quantization parameter rate control method (from -1 to 51) (default -1) -weighted_pred <int> E..V...... Set 1 to enable weighted prediction (from 0 to 1) (default 0) -b_ref_mode <int> E..V...... Use B frames as references (from 0 to 2) (default disabled) disabled 0 E..V...... B frames will not be used for reference each 1 E..V...... Each B frame will be used for reference middle 2 E..V...... Only (number of B frames)/2 will be used for reference -dpb_size <int> E..V...... Specifies the DPB size used for encoding (0 means automatic) (from 0 to INT_MAX) (default 0) -
Read your output:
FFMPEG HEVC/H.265 settings help
By kevindd992002 in forum Video ConversionReplies: 4Last Post: 31st Dec 2019, 22:40 -
Can NVENC beat x264+slow preset?
By sophisticles in forum Video ConversionReplies: 10Last Post: 4th Jun 2019, 17:18 -
What are the max options for Turing NVENC HEVC in FFMPEG?
By Cumberiron in forum Video ConversionReplies: 0Last Post: 28th May 2019, 02:25 -
HandbrakeCLI optimal settings for HEVC NVEnc vs x265
By KDallas in forum Video ConversionReplies: 0Last Post: 15th Feb 2019, 21:33 -
ffmpeg nvidia-gpu-accelerated encoding using NVENC - commandline settings
By hydra3333 in forum Video ConversionReplies: 3Last Post: 7th Sep 2016, 10:11
