what is the sulution it's a 2,24gb movie file how do reduce the file size a bit and no not 900mb bcs i don't want bad resulution but why does this take like 5hours almost
CPU?
Settings and codec >> depends on what you are trying to accomplish, usage, quality requirements, display device, etc -
look i god my pc info in an txt file u can chek it if u want this is an older pc i use trough out the week can u help me further then? i attach the txt file to this
https://files.videohelp.com/u/293738/TOMVEREECKE-PC.txt -
Looks like you have a Core2Duo, 2 threads. You might have to accept the speed you are getting with that system
Without knowing what program and codecs you're using it's hard to advise. And what's the resolution of your source video? Knowing it's 2 GB isn't of much help. You're not going to get very fast, high quality with your 10 year old CPU.
But in general -- try using faster encoder settings. For example, there can be a 100 fold difference in encoding speed between x264's "ultrafast" and "placebo" presets. Even between "veryfast" and "medium" there's a 2x to 3x difference in encoding speed.
Hard Coding Subtitles
By mephistopheles93 in forum Video ConversionReplies: 14Last Post: 9th Jun 2019, 02:28 -
web page coding
By vhelp in forum ProgrammingReplies: 8Last Post: 15th Feb 2019, 08:48 -
ffmpeg Coding Help
By chris319 in forum Video ConversionReplies: 11Last Post: 23rd May 2018, 21:22 -
Regional coding
By Rex Crook in forum DVD & Blu-ray PlayersReplies: 7Last Post: 30th Jun 2016, 14:26 -
Help with coding
By magicbmw in forum Newbie / General discussionsReplies: 4Last Post: 10th Aug 2015, 17:53
