when calling:
I get:Code:mpv.com -vf=pp=help
but no details on how to set the post processing filtes,...Code:Options: subfilters <string> set postprocess subfilters
('mpv.com -vf pp=subfilters=help' just shows the general help)
With mplayer one would use for example:
How can I translate this to mpv, assuming this is still possible?Code:-vf pp=hb=32:39/vb=32:39/deringing/tn=1:2:3/al=f
Cu Selur
Okay, since the mpv documenation isn't really helpful with this I went to the ffmpeg documentation, see: https://www.ffmpeg.org/ffmpeg-all.html#pp and found the solution:
-> so for anybody who uses mpv and is stuck with their documentation, it might be worth to log at the ffmpeg documentation.Code:-vf pp=hb|32|39/vb|32|39/dering/tn|1|2|3/al|f
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Is Mplayer better than mpv?
By vidblue in forum Newbie / General discussionsReplies: 8Last Post: 9th Feb 2019, 13:37 -
mpv and saving
By natty in forum Newbie / General discussionsReplies: 5Last Post: 4th Jan 2018, 04:12 -
Mpv configuration
By hisaishi in forum Software PlayingReplies: 4Last Post: 6th Jun 2017, 17:17 -
VO in mpv?
By fighuass in forum Software PlayingReplies: 1Last Post: 26th Feb 2017, 07:58 -
mpv playlists
By steve6 in forum Software PlayingReplies: 0Last Post: 19th Jun 2016, 06:45
