Hi all, long time listener, first time caller...
I've been downloading some shows from CBC (Canada), using youtube-dlg. But they end up with the sound drifting.
I found that using XMedia Recode, if I copy the audio & video to separate files, then copy them back into a single mp4, it fixes it all up.
So... I've been looking into command-line options, so I can build a batch file. Something I can feed a URL to, and get a finished product with no more user involvement.
It looks like with youtube-dl, I can download the audio & video as separate files?
I think I read that XMedia Recode uses ffmpeg - should I be using this to merge the streams?
How do I do this from command line?
I also saw that youtube-dl uses ffmpeg - would there be a parameter that I can change, that will fix the merge ytdl does, instead?
see here - https://github.com/ytdl-org/youtube-dl/blob/master/README.md#readme
& for ffmpeg - https://www.ffmpeg.org/documentation.html -
Hi ,
An example , on how-to .
Results for previous commandCode:@echo on chcp 1252 > nul "e:\ytbe\youtube-dl.exe" -F "https://www.arte.tv/fr/videos/083261-001-A/amour-fou-1-3/" pause :fin
Choosed 'HTTPS_HQ_1' => New command for catching full vidCode:[info] Available formats for 083261-001-A: format code extension resolution note HLS_XQ_3 m3u8 640x360 VFAUD, Français (audiodescription) 800k HLS_XQ_4 m3u8 720x406 VA-STA, Allemand 1500k HTTPS_MQ_3 mp4 384x216 VFAUD, Français (audiodescription) 300k HTTPS_MQ_4 mp4 384x216 VA-STA, Allemand 300k HTTPS_HQ_3 mp4 640x360 VFAUD, Français (audiodescription) 800k HTTPS_HQ_4 mp4 640x360 VA-STA, Allemand 800k HTTPS_EQ_3 mp4 720x406 VFAUD, Français (audiodescription) 1500k HTTPS_EQ_4 mp4 720x406 VA-STA, Allemand 1500k HTTPS_SQ_3 mp4 1280x720 VFAUD, Français (audiodescription) 2200k HTTPS_SQ_4 mp4 1280x720 VA-STA, Allemand 2200k HLS_XQ_2 m3u8 640x360 VOF-STMF, Français (sourds et malentendants) 800k HTTPS_MQ_2 mp4 384x216 VOF-STMF, Français (sourds et malentendants) 300k HTTPS_HQ_2 mp4 640x360 VOF-STMF, Français (sourds et malentendants) 800k HTTPS_EQ_2 mp4 720x406 VOF-STMF, Français (sourds et malentendants) 1500k HTTPS_SQ_2 mp4 1280x720 VOF-STMF, Français (sourds et malentendants) 2200k HLS_XQ_1 m3u8 720x406 VOF, Français 1500k HTTPS_MQ_1 mp4 384x216 VOF, Français 300k HTTPS_HQ_1 mp4 640x360 VOF, Français 800k HTTPS_EQ_1 mp4 720x406 VOF, Français 1500k HTTPS_SQ_1 mp4 1280x720 VOF, Français 2200k (best)
=============================Code:@echo on chcp 1252 > nul "e:\ytbe\youtube-dl.exe" -f HTTPS_HQ_1 "https://www.arte.tv/fr/videos/083261-001-A/amour-fou-1-3/" -o Amour_fou_1sur3.mp4 pause :fin
DL streams separetly using FFMPEG
Melting vid & aud using FFMPEGCode:@echo on chcp 1252 > nul "e:\ytbe\youtube-dl.exe" -f HTTPS_HQ_2 "https://www.arte.tv/fr/videos/083261-001-A/amour-fou-1-3/" -o AF_1sur3_vid.mp4 ping localhost -n 5 >nul "e:\ytbe\youtube-dl.exe" -f HTTPS_HQ_3 "https://www.arte.tv/fr/videos/083261-001-A/amour-fou-1-3/" -o AF_1sur3_aud.mp4 pause :fin
=============================Code:@echo on chcp 1252 > nul rem === melting vid & aud ; if no problem with aud "e:\ytbe\ffmpeg.exe" -i "AF_1sur3_vid.mp4" -i "AF_1sur3_aud.mp4" -map 0:0 -vcodec copy -map 1:0 -acodec copy "AF_1sur3_ASS1.mp4" ping localhost -n 5 >nul rem === melting vid & aud ; if problem with aud "e:\ytbe\ffmpeg.exe" -i "AF_1sur3_vid.mp4" -i "AF_1sur3_aud.mp4" -map 0:0 -vcodec copy -map 1:0 -bsf:a aac_adtstoasc "AF_1sur3_ASS2.mp4" pause :fin
Cheers .JE SUIS CHARLIE !!!
Need a command line for ffmpeg
By NTradd in forum Video ConversionReplies: 11Last Post: 14th Oct 2019, 11:25 -
ffmpeg command line help
By njscorpion in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2019, 12:42 -
FFmpeg does not convert file through command line
By Vidikon in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2019, 02:13 -
Command Line instruction for non-YouTube sites
By pooksahib in forum Video Streaming DownloadingReplies: 7Last Post: 23rd Jun 2018, 07:16 -
ffmpeg command line syntax
By sambat in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2016, 20:01
