Could someone explain how the pixels are packed in10-bit 420p as output by ffmpeg's yuv420p10le?
Below is the documentation from Microsoft for something called P010. I'm not even 100% sure that is whe same thing ffmpeg puts out when using yuv420p10le.
https://docs.microsoft.com/en-us/windows/win32/medfound/10-bit-and-16-bit-yuv-video-fo...ts#420-formats
It says the video data is contained in the 10 MSB's of a 16 bit word, one word for each channel. Is that correct? To use one would simply shift off the 6 LSB's.
Thank you.
Results 1 to 30 of 36
most likely its planar, so three planes going after each other, Y as full resolution, then U and V as width/half * height/half for 4:2:0
Right, but how are the pixels arranged? Are they still the top 10 bits of a 16-bit word?
If its planar, then 10 bit sample might be as 2bytes, so stride is 2bytes * w, then size for that plane is * h. So for Y - 2bytes * w * h, and accordingly U and V , with that w/2 and h/2. So you need some pointer in memory and read concrete values.
I Vapoursynth when having a plane in an array it is just a_plane[x][y] that returns a value. Same as in numpy. Actually those two in memory could be the same, they are the same. No pointer needed, there is a function that returns memory view.
If is is packed, is very similar though, like YUY2 , packes as YU,YV... then figuring out if you have U or V , odd or even, adjust it to get Y,U and V. -
In this link: https://stackoverflow.com/questions/8349352/how-to-encode-grayscale-video-streams-with-ffmpeg, there is ffmpeg format table , and for PIX_FMT_YUV420P10LE it says planar, little endian,
Al - thanks, but you're talking about how the pixels are addressed. My question is, once you have a 16-bit word, which bits within that word contain the video data? According to Microsoft they are the 10 most significant bits. Is that true with ffmpeg's yuv420p10le?
If you have 16bit word, my impression is that you pull first 8bit as a value , v = pack & 0xFF, shift it 8bits and get another value, v = (pack >> 8) & 0xFF. This is for two byte pack. Or values are reversed if it is other endian. Not sure which one is which now, little or big.
oh I see, that is for packs with 8bit values, you want 10bit, not sure know. Anyway if using Vapoursynth it can avoided. Getting values just by their coordinates.Last edited by _Al_; 26th Feb 2020 at 20:00.
For a 10-bit pixel? No.If you have 16bit word, my impression is that you pull first 8bit as a value , v = pack & 0xFF, shift it 8bits and get another value, v = (pack >> 8) & 0xFF.
FFmpeg normally stores 9,10,12,14-bit values as is (not shifted): maximum 10-bit value is 1023.
Exceptions from this are only in special packed formats like P010 (not sure if it is implemented in FFmpeg).
(yuv420p10le is not P010) -
I've got it drawing in black and white. I have to shift the 10-bit values by 2 to convert them to 8-bit. My hardware doesn't support 10-bit color so it has to be converted.
In the end, I'm drawing 8-bit RGB to the screen. I want to at least be able to decode pixels in a 10-bit file but they must be converted to 8 bits because that's all my hardware can handle. I'm already successfully drawing 8-bit pixels which are read directly from YUV and converted to RGB.
Converting 10-bits to 8 is a simple matter of losing the 2 LSB's.Last edited by chris319; 28th Feb 2020 at 14:51.
...wasting the whole point of 10bit. Dither, my friend.
Scott -
No. if you have 10bit, but only 8 of which you get to use, there are multiple ways to get there.
Truncating as you suggest, is quickest, simplest, but also statistically least true to the original and ugliest.
Rounding is better.
Dither+Rounding is best. But takes most computation, plus since it trades error for noise needs to be tailored to use noise which is most compatible/least disruptive. But the results are often worth it.
Can't afford to get myself a 10bit monitor, much less anyone else.
Scott -
If you are referring to the bitdepth reduction, I'd say do the exact same thing - dither.
If you are referring to the process of color subsampling and any dependent processes, I'd say the point resize method is closest to the way subsampling works in practice, so even though it may be counterintuitive, it should be the preferred method of up/downscaling.
If you are referring to something else, not sure what you're getting at.
Scott -
The crux of this thread is addressing the u and v pixels. In other words, how to fetch those samples out of memory.If you are referring to something else, not sure what you're getting at.
What put it in memory? That'll determine what order it's in.
Regardless there are a very finite number of possibilities, so it wouldn't take much to try all the permutations.
Scott -
Or, you could do what most people do and look at the source code.
Scott -
Chris319 - this is done on many platforms, including ffmpeg that you use, having hard time to understand why you want do it manually,
If you really want to do it yourself, and start with reading values. You came here a while ago with that Burke code to change RGB values, you can modify that. You can see there is all in loop, where inside RGB values are changed inside for each plane. This time you haveYUV planes where U and V is halfed. There are 2bytes per value. When using Python/Vapoursynth and wanting to know YUV value I'd use:
not knowing what equations would follow to get RGB, just to get YUV values.Code:#planar YUV only def get_pixel_values(self, clip, frame, x,y): try: fr = clip.get_frame(frame) planes =[fr.get_read_array(i) for i in range(clip.format.num_planes)] except: pass try: Y = planes[0][y][x] except: Y = 'x' ys = y >> clip.format.subsampling_h #chroma planes are reduced if subsampling xs = x >> clip.format.subsampling_w try: U = planes[1][ys,xs] except: U = 'x' try: V = planes[2][ys,xs] except: V = 'x' return Y,U,V -
It occurs to me that the YUV-to-RGB code will have to change. I don't know if there is anything more to it than multiplying the coefficients by 4 for 10-bits, everything except the luma coefficients Kr, Kg and Kb. So ...
BecomesCode:rf = (255/219)*yf + (255/112)*vf*(1-Kr) – (255*16/219 + 255*128/112*(1-Kr)) gf = (255/219)*yf – (255/112)*uf*(1-Kb)*Kb/Kg – (255/112)*vf*(1-Kr)*Kr/Kg – (255*16/219 – 255/112*128*(1-Kb)*Kb/Kg – 255/112*128*(1-Kr)*Kr/Kg) bf = (255/219)*yf + (255/112)*uf*(1-Kb) – (255*16/219 + 255*128/112*(1-Kb))
Code:rf = (1020/876)*yf + (1020/448)*vf*(1-Kr) – (1020*64/876 + 1020*512/448*(1-Kr)) gf = (1020/876)*yf – (1020/448)*uf*(1-Kb)*Kb/Kg – (1020/448)*vf*(1-Kr)*Kr/Kg – (1020*64/876 – 1020/448*512*(1-Kb)*Kb/Kg – 1020/448*512*(1-Kr)*Kr/Kg) bf = (1020/876)*yf + (1020/448)*uf*(1-Kb) – (1020*64/876 + 1020*512/448*(1-Kb))
Black boxes such as vapoursynth and ffmpeg are not the right solution for every situation. At the end of the day, even your black boxes need low-level code to do their magic. As you know I've already got it working in 8 bits. I'm having trouble with 10-bit video which is a bit underdocumented. Someone here said ffmpeg's yuv420p10le is not the same as P010 as documented here: https://docs.microsoft.com/en-us/windows/win32/medfound/10-bit-and-16-bit-yuv-video-fo...ts#420-formatshaving hard time to understand why you want do it manually
The code is not that complicated if you have good documentation to go by. -
In post #11 you wrote you've got it drawing so it is unclear what you have trouble with. IMO planar layout is trivial and does not need extensive documentation.
Do you mean you have yuv pixels already but cant convert it to rgb? Why not use FFMpeg API to do the conversion? -
I have it working perfectly in YUV -> RGB color in 8 bits. In 10 bits I am able to draw a black-and-white image but am having trouble addressing the U and V samples.
you are severely mistaken, you can manipulate pixel same way as you do, but it is really ridicules. Poisondeathray laid down your yuv to rgb conversion in Vapoursynth, I just simply set it as range full, but he used levels. Did you try those lines? Definitely go that way, you are heading into abyss of looking for new equations for every single format or solution. And doing it pixel by pixel, not under some sort of array is kind insane if you ask me.
To demonstrate what you are trying to do, now say 10bitYUV pipe from ffmpeg, doing the same as you do, loading it into some array, but in Python, I do not use C:
just to get pipe from your ffmpeg to memory , then some sort of array so it can be addressed pixel, by pixel. Above example gets it into Vapoursynth array/frame. That is all that code does. Then converting it to RGB, manually, as you request, which can be done using Expressions in Vapoursynth , but because expressions use reverse polish notation ,it would take a time to figure it out, to write it down, so I passed. You can load that pipe into numpy and do it there as well, if you want that I can post it, but guessing you pass anyway. Then do some algebra en mass for the whole frame, not in some loop for X and then other loop in it for Y. This is why numpy array is here. To do some calculations per frame at once. I have no idea how that would be done manually right now, because there are one line opencv codes (using numpy) that do exactly that, you can dig into their manuals, source code what code they use.Code:import vapoursynth as vs core = vs.core import subprocess import ctypes source_path = r'C:/10bitYUV.mp4' yuv_placeholder = core.std.BlankClip(width=1280, height=720, format=vs.YUV420P10) ffmpeg = r'D:\path\ffmpeg.exe' w = yuv_placeholder.width h = yuv_placeholder.height Ysize = w * h * 2 UVsize = w * h//2 #YUV420 10bit, 2bytes per sample YUVsize = Ysize + 2*UVsize #YUV420 10bit, 2bytes per sample command = [ ffmpeg, '-i', source_path, '-vcodec', 'rawvideo', '-pix_fmt', 'yuv420p10le', '-f', 'rawvideo', '-'] pipe = subprocess.Popen(command, stdout = subprocess.PIPE, bufsize=YUVsize, ) def frame_from_pipe(n,f): vs_frame = f.copy() try: for plane, size in enumerate([Ysize, UVsize, UVsize]): ctypes.memmove(vs_frame.get_write_ptr(plane), pipe.stdout.read(size), size) pipe.stdout.flush() except Exception as e: raise ValueError(repr(e)) else: return vs_frame try: yuv_clip = core.std.ModifyFrame(yuv_placeholder, yuv_placeholder, frame_from_pipe) except ValueError as e: pipe.terminate() print(e) yuv_clip.set_output()
to replace all that insanity above and WITH conversion just using couple of lines instead, using proper loading Source Plugin:
or what pdr posted:Code:clip = core.lsmas.LibavSMASGSource(r'C:/10bitYUV.mp4') rgb_clip = core.std.Point(clip, format = vs.RGB24, matrix_in_s = '709', range_in_s = 'full')
something that would work for you, I do not know why you do not want to go that way, I remember you insisted to get certain RGB values after converting colorbars, which i basically got, not sure where is the problem. I'm sure you'd get help with Vapoursynth or numpy and you have also tools with gui ready to actually read your values right away using vsedit or something else.Code:clip = #sourcefilter #RGB 75% of 16-235 source clip = core.resize.Point(clip, format=vs.RGBS) clip2 = core.std.Levels(clip2, min_in=0.063, max_in=0.92, gamma=1, min_out=0, max_out=1, planes=[0,1,2]) YUV_clip = ... to some YUV
Also I might add, running that code above , that YUV piped from ffmpeg is planar as you can see. Loading Y size first, then U and V.Last edited by _Al_; 4th Mar 2020 at 20:46.
I'm using ffmpeg to read frames into an array. See Ted Burke's code — that's exactly what it does.doing it pixel by pixel, not under some sort of array is kind insane if you ask me.
As an interpreted language, Python would be too slow for pixel-by-pixel.
There are three projects: the first is to limit RGB to EBU R 103 limits. That uses ffmpeg and is finished. The second is to determine the maximum and minimum RGB values to calibrate the second program and to make sure the video is R 103 compliant. That is finished for 8 bits only. The third is to read 10-bit files and to adapt the second program to 10 bits.
10-bit to 8-bit Video File Conversions - the easy (free) way!
By VideoWiz in forum Video ConversionReplies: 10Last Post: 6th Feb 2020, 03:24 -
Help with running 32-bit DLL in 64-bit AVSynth with MP_Pipeline.
By Vitality in forum Video ConversionReplies: 1Last Post: 12th Jan 2019, 16:26 -
16-bit PNG ~> 10-bit MKV GPU encode
By Hylocereus in forum Newbie / General discussionsReplies: 8Last Post: 29th Mar 2018, 23:07 -
MPC HC: 32-bit or 64-bit on Windows 7 64-bit
By flashandpan007 in forum Software PlayingReplies: 20Last Post: 22nd Jul 2016, 09:22 -
why in windows 64 bit I don't see 64 bit codec with DSFmgr?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2015, 09:01
