Hi folks, newbie here...I'm in a fix. Somone offered me the A03 to me for $200.00, and it's used. But I also have an offer for a brand new 104 for about $330.00.
I want the best deal, but if the performance increase is worth the extra $130.00, then I'd go for the 104.
But I need some advice from the experienced folks on this board...which one should I go with?
Thanks for your help...
I would buy the 103 and make sure you have the latest F/W upgrade 1.80 loaded on it. This specs on both drives are similar. The biggest difference is the 104 support HS CDRW media writing and it supports vertical orientation.
RG -
Thanks man...
Well, before you make that jump, make sure that the A03 will fit in your computer (it's longer than the 104). Also, if you don't have a fast computer, then the 104 offers BUFFER UNDERRUN PROTECTION (which can prevent a stack of coasters). It also can use DMA instead of only PIO data modes.
No doubt about it, the 104 is a superior unit, but the burned DVD's are the same. You need to weigh the cost advantage versus the unit features to see if it fits into your "comfort" zone. -
A04 (104) is cheaper $336! Where can you find A03 (103) for that price?
yeah this week there seems to be some good deals on th eA04/104 around, too bad I paid $380 for mine 3 weeks ago....
104 is the oem version and AO4 is the retail the technical stuff is the same but the packaging is different
Pioneer DV-420V
By Vasilii in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Jun 2009, 08:28 -
Pioneer DV-410
By geroglifico in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th May 2009, 05:08 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Can anyone help on this one please - Pioneer 110D
By mattiusb in forum DVD & Blu-ray WritersReplies: 30Last Post: 3rd Jul 2007, 03:37
