    Sep 2015
    China
    I got an error notification when I tried to export a mp4 file in "Using exteneral encoder" on VirtualDub2(Bilud 44220).
    Here is my code:
    Command Arguments:
    -y -f rawvideo -s %(width)x%(height) -r %(fpsnum)/%(fpsden) -i - -f mp4 -c:v libx264 -crf 18 -preset Medium \"%(tempvideofile)\
ID:	52164 Click image for larger version
    my x264_64.exe is new,r159.
    When I add an exteneral audio encoder QAAC,the error notification about audio encoder appeared again.
    Command Arguments:
    --tvbr 91 -q 2 --threading -i -o \"%(tempaudiofile)\" -
    My Command Arguments were copied from others'.
    Where is the problem?
    How can I fix it?
  2. I don't see any mention of the log so here is where you find it: main menu->view->log.
    Testing profiles is quite hard, I'd recommend to start with something that already works and then note any specific changes that you make.
    Some good collection of profiles:
    https://sourceforge.net/p/vdfiltermod/wiki/extenc/attachment/nologic.vdprof
    Sep 2015
    China
    Oh,thank you!I finished it finally!
