Results 1 to 9 of 9
Thread: Join 2 mkv movies, what a mess! Help
  1. #1
    Hello everyone,
    I want to insert an introduction in front of my videos ..
    I'm trying to merge with mkv merge using the append file option
    This is the first file: http://nopaste.tightdev.net/?ID=rav5ry
    This is the introduction that I would like to appear before the film: http://nopaste.tightdev.net/?ID=f991yv
    same resolution, same codec ..
    These are the errors that appear to me: http://nopaste.tightdev.net/?ID=3prmht
    I just can't understand how I have to solve ..
    Can anyone help me?
    Member
    Dec 2005
    Posts
    59,226
    Re: Join 2 mkv movies, what a mess! Help
    The first video is 10bit, the second is 8bit.
    Quote Originally Posted by jagabo View Post
    hi friend, thanks for the reply.
    you're right and I hadn't noticed.
    how can i convert a video to 10bit mkv?
    Re-encode to 10 bit?
    Quote Originally Posted by blud7 View Post
    how can i convert it to 10 bit? is there any software for this?
    You can use x265 or ffmpeg.
    x265 and FFMpeg are both command line tools, but many GUIs exist to make it simpler.
    You need to specify 10 bit encoding in any case
    Member
    Dec 2005
    Posts
    59,226
    Handbrake supports x265 10 bit encoding.
    FPS 30 the introduction, FPS 23.976 the video.
    You have to re-encode the introduction to 23.976FPS with x265 10 bit.
    You can use my smart FFMpeg gui for this.
    https://forum.videohelp.com/threads/395425-New-small-GUI-for-FFmpeg
    Quote Originally Posted by ProWo View Post
    Very thx my friend.. now work
  1. Replies: 3
    Last Post: 26th Jan 2019, 01:32
  2. Replies: 6
    Last Post: 19th Mar 2017, 14:44
  3. Join a series of MKV files to play continuously
    By loninappleton in forum Editing
    Last Post: 28th Jan 2016, 15:38
  4. Replies: 5
    Last Post: 30th Oct 2015, 12:09
  5. how to edit,join and encode movies???
    By Sachin Kerala in forum Newbie / General discussions
    Last Post: 1st Jul 2015, 12:02
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
