I use directshow to get an image. When taking images at 1080p, the image rate drops to 6 fps. How can I fix?
Wild guess - you are using USB 2.0 when you should be using USB 3.0. The difference in speeds exactly amounts to what one would expect in the drop to 6fps at 1080 rez. Likely your webcam cannot do a compressed stream option (e.g. MJPEC, MPEG2, AVC, etc) but just YUV uncompressed.
Problem converting mjpeg format webcam footage
By JJonah in forum Video ConversionReplies: 8Last Post: 20th May 2023, 07:15 -
Elgato Game Capture Hd60 S webcam problem
By kasape in forum Capturing and VCRReplies: 5Last Post: 21st Aug 2017, 07:07 -
Random audio/video sync problem with webcam recorded video
By TinoArts in forum Video ConversionReplies: 2Last Post: 3rd Aug 2016, 12:57 -
Convert 51.43 fps video in 59.94 fps container to straight 50 fps video
By mr_lou in forum Video ConversionReplies: 5Last Post: 8th May 2016, 11:47 -
convert 30 fps time lapse video to 60 fps to speed up and keep all frames
By acem77 in forum Video ConversionReplies: 12Last Post: 19th Jan 2016, 20:01
