I had the idea of adding a watermark to my videos from reading the list of filters. That filter fails on my 64-bit machine with
From reading this thread, I could get a similar result with the overlay function.Code:Cannot load a 32 bit DLL in 64 bit Avisynth: '/path/to/extracted/directory/Watermark.dll'. (/path/to/extracted/directory/example.avs, line1)
I wonder if other options exist, such as converting the source code of the external filter for a 64-bit machine, and if other people have found them.
What is the best way to include a watermark on a 64-bit machine?
Sound like it not the 64 bit computer but rather you are using the 64 bit avisynth instead if the 32 bit version . http://avisynth.nl/index.php/Main_Page. You can use the 32 bit version on a 64 bit computer.
watermark without re-encoding (is it possible)?
By gta5 in forum EditingReplies: 11Last Post: 5th Oct 2018, 12:42 -
Suggestion for cropping, adding watermark, text and color correction
By ShadowWizard in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2018, 08:50 -
how to remove floating watermark in videos
By santhosragav in forum Newbie / General discussionsReplies: 21Last Post: 24th Aug 2016, 23:40 -
How to watermark while encoding with Handbrake
By pras92 in forum Newbie / General discussionsReplies: 12Last Post: 25th Oct 2015, 05:06 -
Sony Vegas: how to merge two videos in order to remove watermark
By virguloso in forum EditingReplies: 35Last Post: 28th Feb 2015, 19:32
