Results 1 to 16 of 16
    Aug 2005
    Europe
    Comodo Internet Security recently started reporting "C:\Windows\System32\wuaueng2.dll" as "Unrecognized". File description is "Windows Update Agent". Was this part of a recent update? What is it about?
    Feb 2006
    1st - check to see if your antivirus software up to date ??
    see this post - https://file-intelligence.comodo.com/windows-process-virus-malware/DLL/WUAUENG
    Aug 2005
    Europe
    I found that both "wuaueng2.dll" and "wuaueng.dll" are in the same folder. Comodo Internet Security is up to date, but only reports "wuaueng2.dll" and does not offer to remove it.
    canada
    It's a windows file and isn't essential,it's your comodo that's at fault.
    Aug 2005
    Europe
    What do you mean isn't essential?
  6. I'm a Super Moderator johns0's Avatar
    canada
    Means it's not required for running windows,it's an update item.
    Aug 2005
    Europe
    I believe it's an update for Windows Update Agent.
    https://support.microsoft.com/en-us/help/949104/how-to-update-the-windows-update-agent...latest-version
    But I wonder why Comodo did not complain about this before.
  8. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    lots of times virus/trojans hide as files that sound like windows files. i have no wuaueng2.dll in my systems folder, but i do have wuaueng.dll(the update agent). i'd upload it to https://www.virustotal.com/gui/home/upload and see if other anti-virus also think it's suspicious.
    Aug 2005
    Europe
    "No engines detected this file" for both "wuaueng.dll" and "wuaueng2.dll". File hashes are different, but Virustotal detects both as "wuaueng.dll".
    Jan 2019
    Europe
    You could try to run sfc /scannow to be on the safe side.
  11. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    yeah,,,,,,, i'd be deleting the "2" file if it were me. it shouldn't have a name close to the actual windows file. if it's a for real windows file you could download it again later if needed.
    Aug 2005
    Europe
    C:\>sfc /verifyfile=c:\windows\system32\wuaueng.dll
    Windows Resource Protection did not find any integrity violations.
    C:\>sfc /verifyfile=c:\windows\system32\wuaueng2.dll
    Windows Resource Protection could not perform the requested operation.
  13. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    could be because wuaueng2.dll is not a windows resource....
    Aug 2005
    Europe
    Latest Malwarebytes (Free) detects nothing.
    Mar 2008
    You can search the registry for references to this file,
    secondly you can use something like Agent Ransack to see if you can find any references to it from an
    exe file. (You can also repeat this search to see if another dll references this dll) For example:
    Aug 2005
    Europe
    I think "wuaueng2.dll" is related to Simplix UpdatePack.
