What are exact disadvantages of converting 24p AVCHD-DVD video to 25p Video-DVD video?
Will there be any disadvantages in audio of converted video?
Title of thread is incorrect!
But I can't edit it now!!
Correct Title:- Disadvantages - 24p to 25p -
Video:
Generally AVCHD is AVC/mpeg4/H.264. DVD is mpeg2, so converting it for DVD compliance will require re-encoding with an mpeg2 encoder requiring a significantly higher bitrate for more or less preserving the AVCHD's quality.
Audio:
It depends how you do the conversion. Typically 24fps film is speeded up to 25fps (+4%) for PAL DVD compliance. Look for AssumeFPS() in avisynth. You would need to adjust the audio as well in order to keep audio and video in sync. You can do this with or without audio pitch correction.
You could also convert the framerate by duplicating or 'pulldown' certain frames or fields, or convert by blending. Look for ChangeFPS() or ConvertFPS() in Avisynth for example, or search for "Euro Pulldown", or use DGPulldown for soft-telecining. All these would preserve the duration of the video and hence no audio correction is needed, however you might dislike the video judder or blend artifacts.
I recommend to study the avisynth documentation. It explains it all much better and in more detail with examples.
Or google for AVCHD and DVD to learn about the format differences. Another buzzword is 'telecine' to address the subject.
But why would you want to convert it at all?Last edited by Sharc; 23rd Feb 2020 at 11:44.
FFMPEG convert 50P to 25P?
By marcorocchini in forum Newbie / General discussionsReplies: 17Last Post: 29th Dec 2019, 15:02 -
from AVC to HEVC - disadvantages
By dira in forum Video ConversionReplies: 1Last Post: 5th Dec 2019, 14:15 -
50p video just patched to play back as 25p - can it be done?
By larioso in forum Video ConversionReplies: 6Last Post: 6th Jun 2019, 22:32 -
Shooting panning in 25p without flicker
By Bencuri in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 29th May 2017, 09:47 -
Convert to 25P or 50P using interlaced footage
By Sir_Loin in forum Video ConversionReplies: 10Last Post: 6th May 2016, 17:08
