Results 1 to 11 of 11
  1. hi there,
    xxxxxx
    Thanks....
    Mar 2019
    Germany
    youtube-dl.exe "https://vod.livestream.com/5e52b21c_b757b9c247fb87dbdc833880140e21a569006c07/events/0000000000897e83/bda6497c-7bc1-484e-81d3-92c00cad75b0_2128.m3u8?start=0&end=10416"
  3. Hi hvq,
    Thanks for the solution. I finally got it to work.
  4. why you delete your request? maybe your question interest other users....
    and if you have find solution, instead to delete your post, write here your solution....
    more people write here your problem, but find solution instead to share your solution, delete their post... do you think it's correct?
  5. the video has this MediaInfo ..OK?
    General
    Complete name : C:\stream\bda6497c-7bc1-484e-81d3-92c00cad75b0_2128-bda6497c-7bc1-484e-81d3-92c00cad75b0_2128.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 2.43 GiB
    Duration : 2 h 53 min
    Overall bit rate : 2 007 kb/s
    Writing application : Lavf58.20.100
    Video
    Format : AVC
    Format profile : Main@L3.1
    Format settings : 1 Ref Frames
    and yes .. it reproduces well in vlc
    責任者-MDX
  6. problem it is not download video (then play on VLC) but how to play video with VLC from url....
  7. Member DB83's Avatar
    Jul 2007
    The OP will probably not come back but if he does he must understand that what he has done is very bad form.
    Topics rarely get deleted on here. And it is just good manners to post on the original thread that he has found a solution. Not remove the post which makes the whole topic meaningless.
  8. yes. very bad behaviour aimed at all of us who are here to read.....
  9. Member Emeritus
    May 2014
    Today, the OP even went to the trouble to go and edit some old posts to ruin those as well. For example, this and this.
  10. DECEASED
    Jun 2009
    Heaven
    Baldrick can undo the OP's stupid edits.
    "Programmers are human-shaped machines that transform alcohol into bugs."
  11. Member DB83's Avatar
    Jul 2007
    Baldrick can undo the stupid OP as well.
