I stopped using GOM player about a year ago, VLC is still loved but it doesn't remember last playback position hence PotPlayer.
I have a TV series whereby the default sound is Russian--audio stream 1. I would like to automatically go on Audio Stream 2--the original English Language.
Now I have to do it manually each and every time. Does anyone know how I can have it do this on its own?
There is a place where you can input preferred language and I have put that into English but it seems to have done nothing.
Preferences > Audio > Language/sync/other > Preferred languages: en eng english
Sometime the audio language is missing in video, so it doesn't work, you can edit video, or use option "Preferred stream: 2". You will have to change it back later though. -
Thank you Dreamer. Your first suggestion, 'language' is what I had and hasn't worked. Your 2nd suggestion 'stream 2' for some reason was greyed out, hence could not be altered. However, I noticed that if you switch from preferred language to preferred stream on the top then the choice becomes available. And it works.
Thank you
Mich
PotPlayer (Default skin): Can I hide unnecessary buttons from controls?
By ahu_lee in forum Software PlayingReplies: 0Last Post: 27th Jun 2017, 15:45 -
Potplayer subtitle language issue
By Chaffee in forum Software PlayingReplies: 6Last Post: 10th Dec 2016, 12:41 -
Potplayer default AR not working
By doomofthemoon in forum Software PlayingReplies: 4Last Post: 19th Mar 2016, 09:05 -
How to set the charset for the second subtitle language in Potplayer?
By ilbrat in forum Software PlayingReplies: 0Last Post: 25th Dec 2015, 03:30 -
How to delete/switch default language in a MKV file
By gquiring in forum Newbie / General discussionsReplies: 5Last Post: 27th Feb 2015, 20:35
