Thought I'd take a shot at restoring Britney Spears "Toxic" as the YouTube version is... horrible.
There are few VOBs I have ripped from DVDs and they all have some form of this reddish ghosting effect.
Although the metadata of this particular VOB file suggests that it is interlaced BFF, TIVTC actually yields better results over all then QTGMC.
Here is an example of a frame using TIVTC, QTGMC, and nothing at all.
QTGMC:
[Attachment 52048 - Click to enlarge]
TIVTC:
[Attachment 52049 - Click to enlarge]
Nothing:
[Attachment 52050 - Click to enlarge]
And here is my AviSynth script which produces the best result yet:
Code:FFmpegSource2("1.mpg") AssumeFPS(29.97) AssumeBFF() ColorMatrix(mode="Rec.601->Rec.709") tfm() tdecimate() BilinearResize(720,540)
Interlaced chroma. You need to follow the script here:
https://forum.doom9.org/showthread.php?p=1582950#post1582950 -
Query about identifying field-blending
By pooksahib in forum Video ConversionReplies: 15Last Post: 19th Oct 2020, 01:59 -
Help with frame blending / ghosting on bad PAL DVD
By autephex in forum RestorationReplies: 19Last Post: 9th Nov 2018, 15:51 -
How to fix this blending/ghosting.
By BÌG•bµdd in forum RestorationReplies: 3Last Post: 20th Apr 2017, 12:03 -
Anime DVD- need help with Frame Blending/Ghosting and mb some other tweaks?
By Mr.Brown in forum RestorationReplies: 3Last Post: 29th Jun 2015, 18:25 -
Removing ghosting/blending/frames from this PAL source?
By killerteengohan in forum RestorationReplies: 14Last Post: 6th Apr 2015, 17:04
