hi guys i am new here. i am trying to use this old recorder and trying to understand what file format is being recorded while recording directly to hdd. my goal is to use this dmr as a media center to convert old vhs and super8 videos into digital (mpeg files or similar.)
any help??
thanks
If you dump the recordings to dvd, then it's simply standard mpeg-2 files as *.vob dvd format (then use mpg2cut2 to convert vob back to mpg).
If you're accessing the hard drive directly, *.vro files.
"Like I said in another post I was able to recover the videos from the HDD in my DMR-HS2 (40GB) by hooking it up to my desktop PC
(I used a IDE to USB2 cable and power supply which I bought on Ebay for $10).
I used a hex editor (WinHex) to clone the HDD Image to a Raw (backup) File, then I could play the whole HDD image with VLC media player (right click on the file and have it open with VLC).
I haven't edited the file into smaller videos yet (but there are Mpeg Video cutters that should do the trick)."
https://forum.videohelp.com/threads/286401-Editing-converting-VRO-files
https://forums.afterdawn.com/threads/panasonic-dmr-e85h-error-u99.332385/
Extracting recordings from Panasonic DVR/BVRs HDD to PC now supported
By jwillis84 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 1st May 2019, 11:04 -
Panasonic DMR es-18
By Joe S in forum Newbie / General discussionsReplies: 2Last Post: 14th Sep 2017, 16:34 -
Cheapest option for Xferring Panasonic HD recordings to external hard drive
By dafoe in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th May 2017, 13:32 -
Panasonic HCX 920 + Hähnel MK200 mic - Pops and clicks in recordings
By Prototype v1.0 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 2nd Apr 2016, 13:38 -
Panasonic dmr-e100h & panasonic dmr e700bd recorders - disc release problem
By nanirdjeff in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Apr 2015, 13:59
