I tried several device, sat receiver, Vcr player, etc... with hdmi, component, composite connection, but all the time I get a “No signal” on the WinTv 10 version. I built myself a HTPC that work just fine, I install the Hauppage Colossus 2 pci express card, I can see Wintv recognize the card as active. Tried the setup with hdmi, component with no success. Any body have idea what I doing wrong?
Thank you
Results 1 to 10 of 10
you are plugging your receivers into the card? they may have some sort of encryption on them like on the hdmi especially if its a commercial receiver like dish, direct, bev or some other paid service. I think its called hdcp
Thank you for your reply, I know about that, but the thing is, I even tried with component. I also tried with vcr, with no success!
The Collosus has multiple inputs. To pick which one to use a video crossbar is set in the drivers. The configuration of WinTV should allow setting the Input. Its possible the Input defaults to the wrong Input and needs to be set to where your connecting the sat or vcr.
I went to my wizard colossus 2 card, I choose hdmi when I connected my sat receiver, no success, after that since I connected my vcr with component, I went back to the wizard and choose component, again no success. Every time for each test I configure also the channel setting, like sat receiver hdmi, for vcr component.
I had that same problem when I had a previous capture card driver installed, as well as the new collosus card installed. I don't understand the interactions, but I had a game capture Ripsaw capture driver installed and got a blank screen with no audio. Even though it was not physically attached to the computer it still interfered. I went into Windows uninstall and removed the driver and capture software for the Ripsaw and magically the collosus started working.
Thank you for your advice, I am not sure if it is that I uninstalled the card driver that fix my no signal or that I went in the advance setting and erase the channels, but everything is fine and I am happy
Glad to hear it
I always forget until its the last thing I try.
It makes no sense.
If you haven't got the hardware installed why would its device driver interfere?
Thus I always forget to try removing the old driver.
Usually I have to install a whole new computer and it works, and then work backwards to the .. ahha moment when I remember what I was doing before the new capture card. -
If gone used HDMI get your self HDMI splitter like a VHD-1X2MN3D
Adding a new External Capture Card to my Hauppauge Colossus Internal Card
By MounaLafi in forum Capturing and VCRReplies: 30Last Post: 21st Feb 2019, 14:40 -
Hauppauge Colossus capture settings
By rds11 in forum Capturing and VCRReplies: 8Last Post: 17th Jun 2018, 20:57 -
Anybody who uses Hauppauge HD PVR 2 or Hauppauge Colossus 2?
By OS_Man in forum Capturing and VCRReplies: 14Last Post: 10th Jun 2018, 11:43 -
Hauppauge Colossus or Hauppauge Colossus 2? Which to get?
By harky in forum Capturing and VCRReplies: 26Last Post: 8th Apr 2016, 11:38 -
Hauppauge Capture with Colossus 2 and STB - Audio Loss
By jcmccorm in forum Capturing and VCRReplies: 6Last Post: 15th Nov 2015, 12:35
