https://www.bbc.co.uk/programmes/m000flwt
Trying to get this. Tried youtube dl with vpn. I have the latest version of youtube dl but I get.
C:\Users\youtube-dl> youtube-dl.exe https://www.bbc.co
[bbc.co.uk] m000flwt: Downloading video page
[bbc.co.uk] m000flwt: Downloading playlist JSON
[bbc.co.uk] m000flwt: Downloading legacy playlist XML
ERROR: Unable to download XML: HTTP Error 404: Not Found (caused by HTTPError())
; please report this issue on https://yt-dl.org/bug . Make sure you are using th
e latest version; type youtube-dl -U to update. Be sure to call youtube-dl wit
h the --verbose flag and include its complete output.
Results 1 to 13 of 13
You can use youtube-dl with a proxy. I used the trial of Hideallip. I think you only get 30 minutes of use with the trial. I had no problem starting the download with youtube-dl using the basic:
Code:youtube-dl https://www.bbc.co.uk/programmes/m000flwt
https://mega.nz/#!ZXgHEQzb!y14X1rS5SXOjRX962zU7yPeaqgAVDHVi87vz6qN__1s
Edit: you can use this with youtube-dl which is downloading for me (with hideallip):
Code:youtube-dl -f worst https://www.bbc.co.uk/programmes/m000flwt
Interesting that Tubedigger was able to download a lower resolution than the "worst" resolution from youtube-dl.
If hideallip cuts off after 30 minutes and youtube-dl hasn't finished downloading, I believe you can just restart hideallip, and youtube-dl will continue downloading the file.
Edit youtube-dl finished downloading the "worst" (704x396)
https://mega.nz/#!VP4XjToR!9oCRfgtrqFZcv8d4hm79sbtmmhC00up2rxtzrkfyt-YLast edited by jimdagys; 17th Feb 2020 at 22:34.
@jimdagys
i have try your hideallip: work with IE but not with chrome (or other).... you use it with chrome?? how to? -
hideallip, for me, work only with browser, not with the whole system. and with browser if started ONLY on your window "launch shortcut"
check your IP on https://whatismyipaddress.com/ before hideallip, then run hideallip and re-check your IP: for me is the same! but if i run my browser from "launch shortcut" window of hideallip then my IP is hidden!
what i want to say is the fact that hideallip only works if the browser is started by the program itself, so for me also other programs outside of hideallip like tubedigg or yt-dl for me don't work with hidden IP ..... confirm this. -
hi sysanin, tanxs for your reply, but i have understand the problem: with browser open (on my case chrome), run hideallip, connect to one server, check my IP and it is the same... but if close my browser, then re-open browser and check my IP, i have new IP hide!
namely first run hideallip, then the browser! I had already tried that button, but my IP was always the same! now i understand how to do it.
anyway tanxs for your reply!
edit: @sys see PM at nsane. here not possible to send...Last edited by lomero; 19th Feb 2020 at 07:43.
bbc radio
By PrinzEugen in forum Capturing and VCRReplies: 4Last Post: 3rd Feb 2019, 19:19 -
BBC i player
By David Banner in forum Video Streaming DownloadingReplies: 21Last Post: 27th Dec 2018, 12:14 -
BBC Store To Close .... ? !!!!
By CJB in forum Latest Video NewsReplies: 8Last Post: 4th Jul 2017, 14:59 -
BBC Iplayer
By Dunmanway in forum ComputerReplies: 1Last Post: 8th Jun 2017, 03:21 -
BBC iplayer help --
By dongy789 in forum Video Streaming DownloadingReplies: 1Last Post: 10th May 2017, 17:01
