I have 1000's of hours of footage recorded in the early days of HDV on cameras such as the Sony HVR-V1U & HVR-Z5U (usually with the HVR-MRC1 solid state recorder installed), and I'm interested in converting the best of that to deinterlaced footage. I have been following Andrew Swan's tutorials on this subject (https://macilatthefront.blogspot.com/2018/10/64-bit-avisynth-and-qtgmc-update-and.html) and I'm really impressed with the results.
As a complete noob to script based video modding / editing (I'm very familiar with Premiere & Resolve GUI editing), I'm looking for some (a lot?) of help on two topics:
1) Andrew only works with Prores on the output side (does not fit my workflow), so all his examples are geared to that. I'd like to output the video back to either something very close to what the camera produced initially, or perhaps some flavor of x264 (recommendations? My computer does not struggle at all with editing x264 files in Premiere, etc). I'm having a lot of trouble coming up with an ffmpeg output command line that would get me to where I need to be - see mediainfo output from original camera file below.
2) Since in some ways we are doubling the frame rate with this process, would it be appropriate to increase the bit rate as well for the saved footage?. I know that most cameras increase bitrate as the frame rate increases, so this seems rational. Also, is there more data to save since the original is only 1440x1080 non square pixels, and now there are 1920x1080 square pixels after the resize to fix the aspect ratio? Again, this seems rational, but neither answer is self evident, or at least not to me.
My avisynth+ script so far (mostly from Andrew's tutorial, computer is an AMD Threadripper 16 core):
SetFilterMTMode("QTGMC",2)
FFmpegSource2("D:\Videos\sample_194456.M2T",atrack =1)
ConvertToYV12()
AssumeTFF()
QTGMC(Preset="slower", Edithreads=8)
BilinearResize(1920,1080)
Prefetch(threads=30)
Batch file to run it:
ffmpeg64 -i "Test-deint-1.avs" -c:v <---------- what should the command be to get something like camera original, should bit rate go up for 60fps???
Here's the mediainfo from an original camera file:
General
Complete name : D:\Videos\sample_194456.M2T
Format : MPEG-TS
Commercial name : HDV 1080i
File size : 162 MiB
Duration : 52 s 419 ms
Start time : UTC 2012-08-05 19:44:56
End time : UTC 2012-08-05 19:45:48
Overall bit rate : 25.9 Mb/s
Maximum Overall bit rate : 33.0 Mb/s
Encoded date : UTC 2012-08-05 19:44:56
Video
Menu ID : 100 (0x64)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High 1440
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Format settings, picture structure : Frame
Codec ID : 2
Duration : 52 s 52 ms
Bit rate mode : Constant
Bit rate : 24.3 Mb/s
Maximum bit rate : 25.0 Mb/s
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 (30000/1001) FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.521
Stream size : 151 MiB (93%)
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 51 s 768 ms
Bit rate : 384 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 41.667 FPS (1152 SPF)
Delay relative to video : 13 ms
Stream size : 2.37 MiB (1%)
Menu
List : 2064 (0x810) (MPEG Video) / 2068 (0x814) (MPEG Audio) / 2069 (0x815) () / 2065 (0x811) ()
Results 1 to 9 of 9
Please clarify something, what is the purpose of this conversion?
If you are preparing material to be edited in Premiere, leave the HDV alone and use it as-is.
If you are making files to watch or share or upload, that's a different matter.
H.264 is far more efficient than mpeg2 (HDV) for encoding so you can get away with a lower bitrate than the original and still maintain high quality. Indeed the 25mb rate of HDV is overkill for a 1080 h.264 video for non-professional distribution.Last edited by smrpix; 13th Feb 2020 at 08:00.
Several reasons...
I'm interested in playing around with Topaz's Gigapixel AI for Windows beta (https://videoai.topazlabs.com/beta). This beta version only works with deinterlaced footage, and it's quite picky about the format. I made a test file using Andrew's Prores example, and the Topaz software totally failed on that (claimed it was processing for considerable time using only 4 of 16 cores, then produced a tiny, unplayable file). I'm sorry if this turns into a TLDR, but it's complex. As I said, I'm quite familiar with using GUI editors, and even working with interlaced footage in them. My interest in Gigapixel stems from the fact that the cameras mentioned above had a nifty, very early High Frame Rate mode that recorded 6 seconds @240i fps to an internal buffer, then wrote that buffer out to a file that most people would call slow motion footage these days. Unfortunately, since this was very early in the HD era, the resolution of those files was low (Sony never published a number, but probably something like 480x360 or less non square pixels in 16x9 aspect ratio) , but upscaled (poorly) by the camera to 1440x1080i. This entire process was automatic and non-configurable, so please don't ask why it was done that way... I don't know, only some (probably retired) Sony engineer in Japan could possibly answer that. I'd love to see if Gigapixel can do anything with those slowmo clips in terms of improving them, even just a tiny bit.
Most of the footage I'm working with involves sports and quick movement. Premiere's handling of HDV interlaced footage has always been a little underwhelming, in my opinion. So I ran some tests on a sample prores file I created using Andrew's tutorial, and I was pleased to see that the edited footage can be exported at 60p (59.94p), and looks noticeably better than just ingesting the native 29.97i footage and working with that. An added bonus is that the deinterlaced file responds well to Optical Flow time remapping (slowmo), and a 50-60% slowdown still looks great, without excessive artifacting. The same can not be said when working with the native camera 29.97i footage. However, I'd still like the option of plugging some of these files into Gigapixel AI, and that can't happen if they are Prores.
So those are my reasons for wanting to create some deinterlaced masters in either mpeg2 similar to the camera master, or in x264 / h264. Thinking further, perhaps x264 / h264 would be more appropriate if I need to increase the bit rate to accommodate more pixels (1440 -> 1920) and more FPS (29.97i -> 59.94p) yet still maintain quality similar to the original...?? -
Thank you for explaining.
In this situation, using ProRes as an intermediate actually seems like a pretty good idea. Not sure why your software wasn't reading it. (Topazlabs are calling for a pretty hefty videocard, I'm sure you've read the specs.)
You might want to try using a lossless codec like Lagarith or Ut as an intermediary. (I've mostly stuck with Quicktime Animation, DNxHD or ProRes, so I can't speak well to the others -- some here swear by them.)
H.264 and its variants require more computing power to decode, so a larger intermediate file may work more quickly. -
Wouldn't you actually want to "descale" the badly-upsized footage after deinterlacing, rather than upsizing it even more prior to AI?
That's the way anime encoders get sharper upscales than official releases. Not sure how good this link is as an explanation; it's just one of the top Google results: https://iamscum.wordpress.com/_test1/_test2/resizing/ -
don't know who or what "andrew" is but i'd dismiss it as trash. capture all the HDV in it's native format. then edit as is to final format. it ain't rocket science.
Why put down something if you don't even know about it? I would never have got as far as I have with deinterlacing without "Andrew's" blog and youtube videos.
For some of us, we want to de-interlace source video's to make them look as good as they can for viewing on progressive displays, simple.
Or, perhaps you were trying to convey something else and I have missinterpreted your post?
Cheers. -
work with the source as much as possible. you either have 60i 1440x1080 or 30p 1440x1080 HDV, for the most part, unless a 720p60 jvc cam was used. the 60i converts nicely to 30p and the HDV 30p already is 1920x1080p30 in square pixels. i gave up on pp long ago and have used vegas pro since about v6.
some options,ConvertToYV12()
AssumeTFF()
your video is already YUV, no need for that ConvertToYV12(),
while making ProRes you do not need to resize, saving resources, just confirm video in your videoeditor as anamorphic 4:3, I think Premiere could do resize just fine, it is already progressive if I understand correctly (hopefully 60p, not 30p) from that avisynth script and Premiere should not make it any worse like it'd came out from avisynth using BilinearResize(), it resizes horizontally only
using HDV a lot too, from old tapes but using vapoursynth, where using QTGMC and transcoding script to ProRes uses 100%CPU all 4threads busy, so that might be an option too with QTGMC deinterlacing:
encoding it to prores:Code:import vapoursynth as vs from vapoursynth import core d2v_file=r'G:/HDV TAPE 68/tape 68-2013_11_16-21_24_07.d2v' clip = core.d2v.Source(d2v_file) from havsfunc import QTGMC clip = core.std.SetFrameProp(clip, prop="_FieldBased", intval=2) #TFF clip = core.resize.Point(clip, format=vs.YUV420P8, matrix_s="709") clip = QTGMC(clip, Preset='Fast', TFF=True) clip.set_output()
Code:vspipe.exe --y4m script.vpy - | ffmpeg.exe -f yuv4mpegpipe -i - -i "G:/HDV TAPE 68/tape 68-2013_11_16-21_24_07.M2T" -map 0:v -map 1:1 -c:v prores -c:a pcm_s24le -y "out.mov"
Strange issue DeInterlacing DV capture - QTGMC-Bob (Hybrid Vapoursynth)
By SupermanTV in forum Capturing and VCRReplies: 23Last Post: 17th Sep 2023, 18:00 -
Solved: Deinterlacing with QTGMC blends frames together
By PRAGMA in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2023, 04:19 -
Deinterlacing Problem - QTGMC & NTSC Footage
By hickeyguy in forum Newbie / General discussionsReplies: 50Last Post: 8th Mar 2019, 12:41 -
QTGMC deinterlacing
By Katherine1 in forum RestorationReplies: 2Last Post: 10th Feb 2019, 11:02 -
Question about FFMPEG deinterlacing methods
By Videogamer555 in forum RestorationReplies: 1Last Post: 25th Feb 2016, 12:01
