Is there any way to convert a PAL DVD to NTSC, keeping the Closed Captions intact.
I know that I can play the DVD with the subtitles and capture the analogue signal. It would be good, however, to find a way of doing this in a totally digital way rather than going digital-analogue-digital.
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
The easiest way that requires no conversion is to get a region free DVD or Blu-ray player and the problem is solved, I myself have a Blu-ray region free player that I play both PAL DVD's and PAL Blu-rays on my US TV. DVD may have a different resolution for PAL but most modern TV's play all resolutions.
N. American closed captions would be highly unusual because countries that typically use PAL for DVD use another system for broadcast TV subtitles. Do you really mean the DVD contains N. American closed captions like those present in TV broadcasts or do you mean the DVD contains alternate language DVD subtitles and/or DVD subtitles for the deaf and hard of hearing?
There are ways to preserve both closed captions and DVD subtitles using totally digital methods, but you'd use different software for doing it depending on which one you have. Closed captions can be extracted with CCExtractor GUI as SRT subtitles and turned into DVD subtitles with SubtitleCreator. DVD subtitles can be demultiplexed as SUP files using PgcDemux.
AVStoDVD can be used to author a NTSC DVD from a PAL video source with up to 3 different audio tracks and 3 different subtitle tracks. [Edit]However, N. American closed captions are stripped from the GOP user data whenever AVStoDVD re-encodes from PAL to NTSC and that is why it is necessary to convert the closed captions to DVD subtitles to preserve them.Last edited by usually_quiet; 15th Feb 2020 at 12:36.
Staxrip and Closed Captions
By kalemvar1 in forum SubtitleReplies: 1Last Post: 20th Feb 2018, 13:09 -
Converting PAL DVD to NTSC and retaining the subtitles
By RBTO in forum Newbie / General discussionsReplies: 50Last Post: 23rd Jul 2016, 12:35 -
Closed Captions/ Subtitle coding
By rgreen in forum SubtitleReplies: 7Last Post: 6th Jul 2016, 16:00 -
My easy way of ripping closed captions
By premiumcapture in forum DVD RippingReplies: 2Last Post: 24th May 2016, 10:47 -
Extract closed captions from PVR
By video2me in forum DVB / IPTVReplies: 56Last Post: 13th Aug 2015, 15:38
