I have been having a hellofa time ripping DVDs i have tried prolly 10 times and only got one good rip. i have tried DVD2svcd DVD2AVI cce tmpg all the regular things. im not exactly new to encoding but pretty new to ripping my dvds. i have been trying to backup my eagles hell freezes over DVD and keep getting floating point error about 30% through the conversion process.. both TMPG and CCE do it. i used smart ripper to ripp the vob files to the hd and then tried dvd2avi and it seemed to work but all i got was static (white noise) for video. so i tried DVD2svcd and tried both encders tmpg and cce both crap out.. WTF.. is there and easy way to convert the VOB files to MPG? i looked at teh DVD how to guide and still had troubles. THE DVD plays fine and ripps to hd fine its always teh re-encoding.. i also tried flask that jsut crashes..i have 2 audio tracks one is DTS the other is PCM i know there are issues with trying to ripp DTS so i have been usign the PCM track. I have been able to extract the audio to wav no problem and vob files no problem..
ALSO what program can i use to JUST encode the VOB files.. DVD2SVCD only lets you chose RIP& encode or just RIP how do i just ENCODE if i already ripped.. i hate having to re rip everytime i have to start over from a fialed attempt i still havethe VOB on my HD
thanks for any help
my system
2000+ AMD XP
512 apacer DDR CL2
2 ibm 60 gigers raid striping(boot drive)
1 30 gig ibm (backup)
TDK 24x10x40 CDRW
16X toshiba DVD
GF2 MX400
WINDOWS XP
dual boot
WIN 98se
i use cce and DVDx 1.8a to rip all my dvd's. the only thing is that you can only have a constant bit rate rip. i use about 1450 bit rate on the CCE for the rip. Try this out it is the fatest and best VCD i can get on my one + year experience of DVD ripping. I have done about 20+ ripps with this and say what i had only one bad rip that is because i made some mistake.
try this out. -
btw....the best method is prolly still smartripper->dvd2avi->tmpgenc
if u followed sefy's newbie guide, u shouldn't have had any problems...
did you encode under winXP or win98...? win98 shouldn't give u any problems -
are you serious...this tells me you've read zero guides, references, faqs, etc. It's a matter of unchecking dvdrip and clicking the file icon left of the cd icon.Originally Posted by Heywould3
I've done eagles hell freezes over and it went just fine. -
thanks guys... ill re-try im sure its me.. i have read guides. ill redo it the way i got it to work the first time. with smart rip dvd2avi and tmpg.. problem is that i kept getting floating point errors in tmpg while trying to do the eagles.. ill re try
again
thanks -
rip with internal routines and your issues should disappear. My strong guess is the problem lies with smartripper.
Problems ripping Precious
By carlos28355 in forum Blu-ray RippingReplies: 7Last Post: 16th Jun 2010, 21:54 -
Mixing all sorts of video (but 1 issue destroys it) HDV flicker
By storhuvve in forum EditingReplies: 7Last Post: 14th Feb 2010, 10:46 -
Ripping Problems
By pepegot1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 23rd May 2008, 09:15 -
Problems ripping this...
By EliteMarine in forum DVD RippingReplies: 7Last Post: 29th Apr 2008, 23:18 -
Having ripping problems
By ezzye23 in forum DVD RippingReplies: 3Last Post: 25th Jun 2007, 13:30
