I'm capturing some old NTSC VHS tapes that I recorded of TV shows many years ago. I capture at 720x480. Which is the correct method to get the proper aspect ratio of 4:3?
1. Crop off the overscan (which is usually 8 pixels on each side) to get 704x480 and then resize to 640x480.
2. Crop overscan, AddBorders to make it 720x480 again, and then resize to 640x480.
Results 1 to 10 of 10
In most cases you slightly blur the frame horizontally by down sizing the resolution, It is a lot better to put an aspect ratio flag into the video than having to physically change its structure.
Or, #3: leave it alone and play in a player that accepts & understands nonsquare PAR. (It should already have the flag if captured & saved properly).
Scott -
I'm capturing with VDub and using Lagarith. As far as I know the avi does not have a flag for playing the correct aspect ratio. I'm saving the final encodes to PC and don't need them to be DVD compliant. They are only going to be played on a PC. I have many many hours of video so I encode with x264 and resize to save space.
Forget resizing since any further processing like that will degrade the image quality more.
If it's playing on the pc, vlc, mphc, etc have the option to set the video aspect ratio upon playback manually, even crop during playback.
(E.g. Right click on the video in mphc to bring up the menu)
This tells the pc how to correctly display the video. -
You're capturing VHS tapes with barely 300 lines of resolution across the full frame. Resizing from 704 to 640 isn't going to hurt them at all.
Actually the horizontal resolution of VHS is inferior than the vertical one, It is barely over an equivalent of 200 pixels compared to 240 vertical (300 is extreme), down sizing it you end up with like 177 active VHS pixels, That's bad. Flagging the aspect ratio can be done during the compression, Something like this:
x value I believe is the number of pixels you want the crop to start from the edge of the frame.Code:ffmpeg -i Input.avi -vf "crop=w=704:h=480:x=0:y=0,scale=w=-1:h=-1:interl=1,format=yuv420p,setsar=sar=8/9" -flags +ildct+ilme -c:v libx264 -crf 10 -x264opts bff=1:colorprim=smpte170m:transfer=smpte170m:colormatrix=smpte170m:force-cfr -c:a aac -b:a 192k Output.mp4
CropResize - Cropping & resizing script
By hello_hello in forum Video ConversionReplies: 136Last Post: 20th Dec 2025, 06:37 -
resizing videos while accounting for cropping and aspect ratio
By vhelp in forum Video ConversionReplies: 40Last Post: 11th Dec 2016, 01:10 -
Convert from .ts to .mp4 while cropping black bars & little quality loss?
By nobodyhome in forum Video ConversionReplies: 3Last Post: 31st May 2016, 12:49 -
Subtitle Edit & Microsoft .NET Framework Proper Version
By devilcoelhodog in forum SubtitleReplies: 1Last Post: 10th May 2016, 12:06 -
What's the difference from resizing to 640x480 before cropping and after?
By CZbwoi in forum RestorationReplies: 23Last Post: 3rd May 2016, 15:11
