https://forum.videohelp.com/images/imgfiles/rPNok09.jpg
how can i adjust font size for potplayer when pressing "tab" it shows these info.
thank you!
Right click Video window --> preferences --> General --> OSD display
The font on most any program gui is set during creation so that it will display correctly on that form. It appears potplayer chooses a font that allows the long line of information to display without needing multiple lines for a single line of information. That is why if you stretch the window the text also grows and becomes more readable. I find no area in preferences to set the font greater than what will display larger than what will allow the longest line to appear unbroken.
If it's just to be able to read, stretch the player form stretches the text
PotPlayer + Mad VR = no on screen file info...
By qwecxz in forum Software PlayingReplies: 1Last Post: 27th Jan 2019, 13:34 -
How to change info in Titlebar of Potplayer?
By reelism in forum Software PlayingReplies: 0Last Post: 20th Apr 2018, 16:08 -
PotPlayer - watermark or any text ?
By JohnWeeed in forum Newbie / General discussionsReplies: 4Last Post: 1st May 2017, 06:50 -
How to remove file information display from Potplayer?
By Mystery123 in forum Software PlayingReplies: 11Last Post: 30th Apr 2016, 10:22 -
PotPlayer and colored text (SOLVED)
By suadnovic in forum Video Streaming DownloadingReplies: 7Last Post: 30th Nov 2015, 04:55
