I just used DVDFab to copy a disc, and my issue is that the VIDEO_TS folder was 7.58 GB upon completion. Usually, a VIDEO_TS folder is copied at 4.19 GB. This is the only disc out of a myriad of disc that I have copied with DVDFab that the folder is 7.58 GB. I have used 3 different discs, and the same result. Of course, I cannot burn it to a 4.75 GB disc.
Is there a way to condense the folder to 4.19 GB?
Results 1 to 19 of 19
That's because you are performing a "Full Disc" RIP to DVD9. Select DVD5.
Google is your Friend -
This is because I want to copy a full disc. Each full disc has always been 4.19 GB.
How do I accomplish this with this one disc? -
with the disc in the drive start dvdfab, once dvdfab has analyzed the disc click the little wrench icon (advanced settings)
where it says output you should see settings for dvd9 or dvd5 choose dvd5 to have dvdfab shrink the disc to fit on
a recordable disc. -
in the upper right hand corner of the dvdfab interface click the arrow, click common settings - drives -
dvd write - writable media (dvd-5 size) in the drop down box click customize enter your desired size and click okLast edited by october262; 10th Feb 2020 at 13:57.
I will do this, but this is the size that has always worked for every full disc before.
please check your pathplayer settings, click common settings - dvd - pathplayer - make sure "always enable pathplayer" is checked
then click on dvd protection and make sure that "enable cloud decryption service" is checked
it sounds like some copy protection isn't getting properly removed. -
They are both already checked.
Maybe some copy protection isn’t getting removed. It is only for the second disc in the series first season. I have tried 3 different discs, and the same result.
DVDFab will not read a disc
By jarod1005 in forum Newbie / General discussionsReplies: 12Last Post: 16th Oct 2019, 13:36 -
disc open in anydvd not seen in dvd shrink
By agent222 in forum DVD RippingReplies: 15Last Post: 1st Dec 2018, 11:24 -
Why can't DVDFab rip/see all episodes on my retail DVD-DL disc ?
By Subzero11 in forum DVD RippingReplies: 11Last Post: 19th Aug 2017, 11:13 -
Shrink Movie Collection down to a smaller size
By adrian2055 in forum Newbie / General discussionsReplies: 5Last Post: 30th Sep 2015, 01:11 -
[SOLVED] [ffmpeg] Ways to shrink down file size?
By yetanotherlogin in forum Video ConversionReplies: 5Last Post: 4th Aug 2015, 04:47
