Hi i have some movies etc put on a usd stick for me as per panasonic instructions using mkv and srt subtitles text files...the models of blu ray recorders i have are dmr bwt450 and bwt 720. The pictures play perfectly but the subtitles dont come up on both machines.I have tried everything to make them work on both machines but they just dont... how can this problem be fixed thanks?
Results 1 to 11 of 11
did you try having 2 separate files, one with video/audio and the other as srt. as in movie.mp4 and movie.srt more devices can use mp4 than mkv.
Both Panasonic recorders require separate subtitle files in the same folder as the MKV file.
From the operating instruction for the Panasonic DMR-BWT450:
Subtitle file types compatible with an MKV video file: ".SRT” “.srt” “.SUB” “.sub” “.TXT” “.txt”
• The video file and subtitle text files are inside the same folder, and the file names are the same except for the file extensions.
• Some files may not be played back even if they have these extensions.
From the operating instruction for the the Panasonic DMR-BWT720:
Subtitle file types compatible with an MKV video file: “.SRT” “.srt” “.SSA” “.ssa” “.ASS” “.ass”
• The video file and subtitles text file are inside the same folder, and the file names are the same
• Some files may not be played back even if they have these extensions.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
How do yiu set yours up exactly so its works? Everything we have done has been correct so far so cant understand why it doesnt work...
Nobody in the USA has either of your Blu-ray recorders. Machines like yours that function as PVRs for HDTV broadcasts as well as Blu-ray players have never been available here.
However, some US-model TVs and Blu-ray players have built-in media players capable of playing MKV files and subtitles with similar requirements for subtitle playback. The subtitle and mkv must be in the same folder and use the same name, for example, mymovie.mkv and mymovie.srt. I have only used srt with mkv but I have not had a problem with the LG Blu-ray player I use.
Perhaps the format for your subtitle is slightly non-standard or the character set used is wrong.Last edited by usually_quiet; 9th Feb 2020 at 00:43. Reason: grammar
Is there a subtitle setting in the menu or on the remote control?
No its nothing to do with the subtitle button.. if anybody has made subtitles work on panasonic recorders on a usb stick please tell me exactly how you did it please.
I know that you are waiting for someone in Australia with one of your recorders to help you but it may be a long wait. In the mean time, if you uploaded a subtitle file that won't play to VideoHelp it might allow someone with experience in diagnosing problems with subtitles figure out what is preventing that file from playing.
Often the problem lies with the character set. Some examples: The srt file might be in Unicode UTF-8, but the player only understands ANSI. Another common problem is the srt file uses ANSI encoding but the player can't use the ANSI character set for that language.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
might be obvious and already mentioned, but subs must have identical filenames as the video they belong to
Old usb memry stick change created fails
By Budman1 in forum ProgrammingReplies: 4Last Post: 10th Jun 2017, 12:54 -
Fix: TV or player not recognizing USB memory stick
By Doogy2Shox in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th May 2017, 14:47 -
mp4 files not playing from a usb stick
By jacob2014 in forum Newbie / General discussionsReplies: 7Last Post: 16th Feb 2016, 18:03 -
Avermedia Volar Max Hybrid USB stick stopped working
By OrangeDriver in forum Capturing and VCRReplies: 7Last Post: 19th Oct 2015, 00:57 -
Blu-ray Player Not Recognising USB Stick
By Teac23 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 16th May 2015, 18:12
