  1. Hi. I often use this command at the beginning of a scene edit:
    loop(250,9999,9999).trim(9999,9999+249).amplify(0).fadein0(25)
    Is it possible to make a 'function' of the loop part so that I can simplify my scripts something like this:
    rpt(999,250,25)
    meaning, repeat frame 999 250 times with a 25 frame fadein. If possible, 'Amplify(0)' would be incorporated into the function.
    Grateful thanks for any thoughts you may have.
  2. You may eventually get a relevant reply here, but you might get more in-depth replies at Doom9, which has an entire section dedicated to Avisynth.
  3. Thanks, abolibibelot. I've been trying to get my head around functions by reading this page:
    http://avisynth.nl/index.php/User_defined_script_functions
    but it's proving to be beyond someone like myself who came to computers later in life. I'll hang around here for a while as I've had enormous help from members of this forum in the past.
  4. assuming I didn't overlook something:
    function rpt(clip input, int frame, int times, int fadeIn)
       clip = clip.loop(times,frame,frame).trim(frame,frame+times-1).amplify(0).fadein0(fadeIn)
       return clip
    should do the trick.
    Cu Selur
  5. Hallo, Selur und Vielen Dank for that. Very kind of you to take the time. I've tried using
    rpt(999,250,25)
    on an existing script but I get an error message saying the video stream cannot be opened. Am I 'calling' the function correctly?
  6. fixed:
        input.loop(times,frame,frame).trim(frame,frame+times-1).amplify(0).fadein0(fadeIn)
  7. Superb, jagabo, thank you so much. It looks simple but I just can't 'read' that programming. I did, however, write a function to do a loop with a fadeOUT. That was easy...
    Thanks again, and to you, too, Selur.
  8. doh overlooked that I renamed the clip to input so
       input =  input.loop(times,frame,frame).trim(frame,frame+times-1).amplify(0).fadein0(fadeIn)
       return input
    also should work.
