Results 1 to 18 of 18
  1. hello all ive been wanting too use multiAVCHD but after installing and adding videos , i go to use the menu feature and i keep getting a avisynth is not working properly error .... can anyone help with this issue please , im using windows 10 64bit
    canada
    Did you install avisynth?
  3. Originally Posted by johns0 View Post
    yes and all other applications that was said to install with the software but no joy
    Jul 2008
    Old Dominion
    You must install the recommended versions of software. This guide can walk you through what is needed.
    http://adubvideo.net/how-to/setup-proper-playback-chain-windows
  5. Followed step by step and still get the error message - avisynth not working properly .... so i have no idea what to do now
  6. I'm a Super Moderator johns0's Avatar
    canada
    Right click on multiAVCHD 4.1 and check 'run this program as an administrator'
  7. Originally Posted by johns0 View Post
    just try'd that and still says the same
  8. I'm a Super Moderator johns0's Avatar
    canada
    Uninstall avisynth and reinstall it.
  9. Originally Posted by johns0 View Post
    thank you for your help , but iv'e tryd that with no joy as i still get the same error
  10. I'm a Super Moderator johns0's Avatar
    canada
    Do you have any other programs installed such as k-lite?They are know to give issues.
  11. Originally Posted by johns0 View Post
    no none
    Mar 2008
    Which version of Avisynth have you installed?
  13. Originally Posted by davexnet View Post
    2.58 and 2.60 and uninstalled each and re-tryd and tryd and tryd again
    Mar 2008
    Have you confirmed basic Avisynth functionality by trying to open simple scripts
    in Virtualdub2 (for example) ?
  15. The same issue, I am encountering with K-lightCodec, avisynth2.58, and multiAVCHD4.1.771. I have several machines, win10Pro or win8.1 are installed.
    Under one win10Pro machine, "avisynth is not working properly" is reported when trying to create menu. Whereas, menu creation goes with no error under another win10Pro machine OS newly installed. There, in all cases I confirmed Avisynth were installed properly with testing avs scripts under VirtualDub2.
    Even if re-installing K-lightCODEC, avisynth and MultiAVCHD, status cannot be changed as to "bad" machine. In addition, the same cases are observed as to Win8.1Pro machines.
    Until now, I have not found the reason why error is reported on the specific machines. As to name "avisynth" or "multiAVCHD", registry difference is not found between "bad" machines and "good" machines.
    Maybe, installing of some other applications might be caused harmful for AVCHD's operation.
    May 2020
    Baracas
    These types of programs are quite problematic, in a moment I put another with better benefits.
    May 2020
    Baracas
    Evaluating multiAVCHD also gives some headaches. Apparently there is no correct program and you cannot mix several in order to get the best one.
  18. Member
    May 2020
    Baracas
    avisynth, is not working properly it's the worst of all, the machine hangs
